Question about Lite On (LTR-52327S/5238S) (LTR52327S5238SBKRE) CD-RW Burner
Lite On LTR-52327S
My Cd Burner used to work once in awhile but now when I load a cd into drive D it says to load a cd. In Device Manager ....it says everything is working ok
  • cowboydmp Feb 06, 2009
    same problem..won't read or burn disks....ejects disk and repeatedly asks to install a disk, then ejects it again after trying to read it!
We bought a new cd burner
Posted on Jun 15, 2008
Code 19 error indicating corrupted registry. I've tried uninstalling and reinstalling but nothing works. I have the same problem with my memorex DVD ROM/CD RW drive. I think Norton 360 trashed my registry
yeah, if your registry has been trashed. you should use some registry defrag tools to fix it. I know a <a href="http://www.system-tools-software.com/free-registry-defrag/">free registry defrag</a>, you can look for it and have a try. Good luck!
Nov 09, 2009 | Lite On LTR-52327S CD-RW Intenal IDE...
Not detecting any discs, any ideas why?
Need to install or update driver for it. Go to Control panel- System files- find and click hardware tab, then open device manager and see if your lite on cd is there and if your connected to the internet click update driver. If it wasn't there then your need to find the software or driver for it.
Go to this site and select at category optical storage. then select your model number and download and execute
http://us.liteonit.com/us/index.php?...pper&Itemid=75
Hope this helps
Sep 24, 2009 | Lite On LTR 52327S CD-RW Burner
CD ROM MODEL LTR-48327S IS MY CD BURNER WHEN I added a new cd/dvd player burner my cd burner quit working what is the problem?
each one has jumpers on the back. tiny plastic thing that slides over two pins. there are six pins. three sets of two. one device must be set to master one to slave or they wont work.
they are usually labeled with a picture or M S CS
master, slave, cable select.
Aug 22, 2009 | Lite On LTR-48327S CD-RW Burner
Installer
Depending on your opearating system CD-WRITER LITE-ON LTR - 52327S and any other cd writer lite- on are plug and play devices which does not need an installer.
All you need to do is properly connect your CD writer on your pc while your machine is off, when you turn on your computer it should be displayed under my computer.
If its not shown under my computer window then its either.
1. Your device is not properly connected
2. Your device have a power fauilure problem
3. Your cabling is faulty
If your device is connected but does not function properly you can
1. update your driver
Mar 24, 2008 | Lite On LTR 52327S CD-RW Burner
Trying to find the driver to install for the cd-rw
Please download the driver file from this location its an exe file so when you will finish downloading click on open folder where you can find the correct driver file, and rest i think you know how to install it.
http://drivers.softpedia.com/get/FIRMWARE/Lite-On/LiteOn-LTR-52327S.shtml
Regards
Moses
Jan 13, 2008 | Lite On LTR 52327S CD-RW Burner
Lite-on LTR-52246s
As a first step try running this and then reboot the computer. Sometimes windows loses track of CD drivers. I see one or two computers a week at work with this problem. If they doesn't work it could be a few other things, let me know if it works.
Good Luck,
Matt
Nov 10, 2007 | Lite On LTR 52246S CD-RW Burner
How can I fix this. (The door won't stay closed)
The problem can be fixed but probably not at your end. Get it done bya trained technician.
Oct 06, 2007 | Lite On Lite-On 52x32x52 CD-R/CD-RW IDE...
CD-RW Problem
There some few tips you can try. Power down the computer then open the cd tray by inserting a sharp object in the small hole near the tray. Look for this hole, then using the sharp object push it pretty hard. With the other hand try to pull the tray out. Once you've pulled it power on the computer (with the cd-rw's tray opened) and watch what the cd-rw is actually doing now. If after it retracts the tray it is doing the same, you will need to dissasemble it. If you are willing to try this, please post another message and also specify there what did the cd-rw drive do when you've applied the method i've told you before.
Mar 11, 2007 | Lite On (LTR-52327S/5238S)...
CD-RW Problems
First, try this:- Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers. If that doesn't work, take off the side of the pc and and look to the back of your burner. You will see an ide cable connected to the back, either try a new cable or try the cable that is connected to the hard disk drive, as there will be another connector available. If you do use the burner on the same cable as your HDD then you will have to set the jumper on the back of the burner to slave. It could be a bad cable or faulty ide motherboard connection.
Mar 11, 2007 | Lite On LTR 52327S CD-RW Burner
Lite On (LTR-52327S/5238S) (LTR52327S5238SBKRE) CD-RW Burner Logo
106 people viewed this question
Top Lite On Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Steve
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
