How do i remove a disk drive from a toshiba satellite L25-s1195 laptop
  • 93 Answers
If you are talking about the CD/dvd drive you have to take it apart which WILL void your warrenty. Usually one of the screws underneath also holds it in place otherwise it is located under keyboard. I do not recommend taking a laptop apart unless you know what you are doing. if you damage one of the many this ribbon cables it will not work when you put it back together. If you are talking about the hard disk then there is an access pannel underneath that has a picture of what looks like cd's stacked on top of eachother representing the platters that are inside a hard drive.
Posted on Nov 04, 2010
I have a toshiba lap top that when it connects to inter net wont hold and now I can't get sign in page
It seems like you intetnet explorer has crash down due to many reasons it cant be corrected eaisly so I suggeyt you to use another browser like chrome or mozilla
Feb 23, 2015 | Toshiba Satellite L25-s1192 / L25-s1193 /...
Wher i can download L25-s1194 vga driver for toshiba
http://download.cnet.com/vga-driver-ati-8/3000-18492_4-197341.html
http://download.cnet.com/1t2xw26-exe/3000-2122_4-120557.html
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to try a few times to get it right
hope it helps you
Apr 19, 2012 | Toshiba Satellite L25-s1192 / L25-s1193 /...
I want install l25-s1194 vga driver for toshiba
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red X right click select reinstall drivers
http://download.cnet.com/acjxw01-exe/3000-2108_4-120624.html
hope it helps you
My toshiba satellite l25-s119 turns on but the screen is blank?
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 27, 2011 | Toshiba Satellite L25-S119 Notebook
Replace cd rom with a dvd+rw cd rom in a toshiba satellite
You should be able to, there is usually only one screw holding the drive in, if you hold the replacement up to where the instlled one is, you should see the approximate location of the screw ( may be under another panel, Memory,hard drive etc.., the drive will just slide out, then make sure the connectors are the same, and swap or place the mounting bracket on the new one, and slide it back in place, replacing any screws removed
Mar 26, 2009 | Toshiba Satellite L25-S119 Notebook
How can i recover my laptop to factory settings?
Applicable Models: Satellite L15-S104, L15-S1041, L20-S310TD, L20-SP231, L25-S119, L25-S1194, L25-S1217, L25-S1213, L25-S1215, L25-S1216, L25-S1196, L25-S1211, L25-S1214, L25-S1212, L25-S121, L25-S1193, L25-S1192, L25-S1195, L35-SP1011, L35-S2366, L35-S2316, L35-S2206, L35-S2194, L35-S2174, L35-S2171, L35-S2161, L35-S2151, L35-S1054, P100-ST7111, P100-ST9212, P100-ST9712, P100-ST9742, P100-ST9772, P100-ST9762, P100-ST9752, P100-ST1072, P100-ST9732, P100-ST1071, P100-ST9412, P100-ST9612, P100-ST9012, P100-ST7211, P105-S921, P105-S931, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6134, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S6034, P105-S6024, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6074, P105-S6054, P105-S9312, P105-S6014, P105-S6002, P105-S6004, P105-S6012 << hideThe printed instructions included with the Recovery and Applications/Drivers Media disc are correct for most computer models. For some models, however -- including those listed above -- booting from the Recovery disc requires pressing the F12 key, rather than the 'C' key. The instructions below are correct for these models.
CAUTION: The Recovery process reformats the computer's hard disk drive, which completely erases its contents -- including all applications, all documents, and all other data stored on the drive. Be sure to back up your documents and other data before following the instructions below.
Follow these steps to erase the current contents of the hard disk drive and to re-install all of the software that was installed on the computer when it was manufactured:
1. With the computer on, insert the first Recovery disc into the optical drive.
2. Shut down the computer (click the Start button, click Shut Down, select Shut Down, click OK).
3. Press the computer's power button to turn the computer on, and then immediately press and hold the F12 key. Release the F12 key when the menu of boot options appears.
4. Use the arrow keys to navigate to the CD/DVD option. Press the Enter key to select it.
The computer will restart, and will boot from the Recovery disc.
5. Follow the instructions on the screen to start the Recovery process.
CAUTION: Once the Recovery process has begun, do not interrupt it.
The computer's hard drive will be formatted, erasing its contents. All of the software that was installed on the computer when it was manufactured will then be re-installed.
6. Once the Recovery process is complete, remove the Recovery disc, and press any key to restart the computer.
- mc/wa
Jan 27, 2009 | Toshiba Satellite P105-S6207 Laptop
Recovery disk for my laptop
If it is the drivers you require the Toshiba webite should have them. If you call them with make/model seriel # they may be able to provide you with a replacement recovery disk. Hope this helps.
Dec 24, 2008 | Toshiba Satellite L25-S119 Notebook
Factory settings
There's a couple of things you can do:
Press the F2 key to enter the BOIS setup and reset those defaults
and/or
Use the driver disc. It writes a complete image on the hard drive with all the drivers.
Apr 03, 2008 | Toshiba Satellite L25-S119 Notebook
Toshiba Satellite L25-S119 No boot
reset bios to default try installing fresh system
Jan 10, 2008 | Toshiba Satellite L25-S119 Notebook
Computers & Internet Logo
Alun Cox
David Payne
David Payne
