I have an acer AL2416W monitor and I keep getting a pop up window that says empowering technology with the following options: User, text, standard, movie It keeps on popping up all the time and its annoying. I don't know how this happened. Its been working fine all this time. Is this a monitor issue or a computer issue? Can someone please help?
SOURCE: menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Posted on Feb 28, 2008
skotkolr
  • 558 Answers
SOURCE: acer monitor auto config screen pops up every 5-10 seconds
hope you got an answer
Posted on May 02, 2008
SOURCE: monitor switchs between digital and analog
I had a similar problem, the monitor was going blank once in a while (since I don't have a VGA input), so I switched the Auto Source feature to "Manual" and so far it's working fine for the past 2 days, if I run into the problem again I'll update this message.
On the side panel of your monitor, press the top button to access the menu, scroll down to the setup menu (by pressing the 3rd button down on the panel), press the 4th button down to enter the setup menu, scroll down to "Auto Source", use the 4th button to select, "Auto" & "Manual" are your choices.. press the 2nd button down to select "Manual" then the top button to exit the menu(s).
This monitor is set up to be able to do multi display with the software included. Utilizing both Digital and Analog signals. I'm not using this feature so I'm not sure how switching the Auto Source off will affect the performance of this feature.
Posted on Jan 02, 2009
  • 10 Answers
SOURCE: The Volume Screen on my monitor keeps popping up
Try putting pressure on the monitor near the buttons. There might be a short or some type of stress pressing the buttons.
Posted on Mar 24, 2009
babes_ganda0
  • 381 Answers
SOURCE: monitor control panel keeps popping up on screen
hi..if you soldering iron or do you have a electronic technician you need help him.the defective parts need to replace is Tack switch inside the CRT/Monitor..Thanks and Good Luck...^_^
Posted on May 10, 2009
Empowering Technology screen keeps popping up...can't get rid of it
Go to start,type in Msconfig and press Enter.You will see a box with a section labelled Startup.Click on that and look for Empowering Technologies in the list.Any with that description,remove the checkmark and the go to lower right corner of the box and click apply then ok,then restart your computer.That should fix your problem..good luck :)
Sep 01, 2014 | Acer T232HL 23" LED LCD Touchscreen...
I have lost my acer empowering technology bar how do I reinstall it
You can download it here http://www.acer.co.uk/ac/en/GB/content/drivers
You must select your computer, and it will show you download links
May 02, 2011 | Acer Computers & Internet
I have an Acer Aspire 5720, ive had it for a year now and it is starting to slow down. I have lost the booklet to it and i need to do a master reset on it. Ive already backed everything up im just finding...
This was taken straight out of the manual for your model, which can be found here.
Acer eRecovery Management
Acer eRecovery Management is a tool to quickly backup and restore the system.
You can create and save a backup of the current system configuration to hard
disk, CD or DVD. You can also backup/restore the factory default image, and
reinstall applications and drivers.
Acer eRecovery Management consists of the following functions:
1 Create backup
2 Burn backup disc
3 Restore and recovery
This chapter will guide you through each process.
Note: This feature is only available on certain models. For systems
that do not have a built-in optical disc burner, plug in an external
optical disc burner before entering Acer eRecovery Management
for optical disc-related tasks.
When using Acer eRecovery Management, you may be prompted to enter the
Empowering Technology password to proceed. The Empowering Technology
password is set using the Empowering Technology toolbar or when first running
Acer eLock Management or Acer eRecovery Management.
Create backup
You can easily create full and fast (incremental) backup images of your system
configuration to hard disk from the main Acer eRecovery Management screen.
Note: Fast (incremental) Backup is only available after a Full
Backup is made.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 In the Acer eRecovery Management window, select the type of backup you
want to create using Full or Fast.
3 Follow the instructions on screen to complete the process.
83
English
Burn backup disc
Using the Burn Disc page of Acer eRecovery Management, you can burn the
factory default image, a user backup image, the current system configuration,
or an application backup image to CD or DVD.
2 Switch to the Burn Disc page by selecting the Burn Disc button.
3 Select the type of backup (factory default, user, current system,
application) you would like to burn to disc. Choosing to burn a user backup
will burn your most recently created backup image to disc.
4 Follow the instructions on screen to complete the process.
Note: Create a factory default image when you want to burn a
bootable disc that contains your computer's entire operating
system as it was delivered to you from the factory. If you wish to
have a disc that will allow you to browse the contents and install
selected drivers and applications, create an application backup
image instead — this disc will not be bootable.
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
Dec 20, 2009 | Acer Aspire 5720 Notebook
How can i reformat my laptop on CD acer aspire 3000
Using Acer eRecovery Management
You can launch Acer eRecovery Management in a number of ways:
Acer eRecovery Management requires a password to activate. The default password is six zeros (0s).
Note: These steps will return the system to the original factory installation including all factory installed drivers and applications.
Back up all data prior to using this procedure.
  1. Plug in the AC adapter and battery.
  2. Turn the system on
  3. Immediately, press ALT on the keyboard and start tapping F10.
    Continue holding ALT and tapping F10 as the unit boots up.
  4. A screen stating "Starting Acer Erecovery" should appear.
    (Release ALT and stop tapping F10 at this point)
  5. There will be 4 options:
    1. Restore system to factory default
    2. Restore system from user backup
    3. Restore system from cd/dvd
    4. Exit
OR
From the Start menu, go to Start > (All) Programs > Empowering Technology > Acer eRecovery Management.
Or try this By clicking on the Empowering Technology icon from your desktop, or pressing the key to launch the Empowering Technology user interface. Select the Acer eRecovery Management icon.
Oct 11, 2009 | Acer Aspire 3000 Notebook
Empowering technology framework incompatible with vista ultimate
downlaod all Empowering tech software from Acer direct for ur notebook
see link pls rate FIXYA fo rhelp
ftp://ftp.support.acer-euro.com/notebook/aspire_5315/vista/Applications/
Apr 18, 2009 | Acer Aspire 5315 Notebook
Acer elock
You don't need to pay acer the 100usd to get the password removed,
one thing you can try first, is to disable the elock service from
start -> run -> type in services.msc
look for elock service right click properties startup type disabled and stop the service, on some elocks this is enought to stop it from working. but it debends I can fix this and I have done it many times now..
Nov 29, 2008 | Computers & Internet
http://support.acer-euro.com/drivers/notebook/as_5920.html
all the drivers there, you just have to download and install.
Oct 31, 2008 | Computers & Internet
ERecovery error
Acer....gotta love it...
You aren't alone when looking for help with Acer's framework technology.
What you're going to want to do is use the Msconfig utility to work around this problem. To start msconfig click on Start, select Run, type msconfig in the Run text box then click on OK.
Next select the Startup tab when msconfig opens. Look in the list for eRecovery Service and uncheck it. Select Apply and then OK when done. It will pop a message that a restart is require for changes to take effect. Restart the system.
From what I've read, this may or may not completely fix the INT15 Error eRecovery must be terminated error message. If it doesn't, go back into msconfig/startup and look to see if PCMService has been unchecked. If so, recheck it, select apply and OK, then reboot.
This was all the info I could dig up so I'm not 100% sure if the suggestions are guaranteed to work.
Good luck and let us know if it helped
Feb 28, 2008 | Acer Aspireā„¢ T180 PC Desktop
ACER ASPIRE 9302 WSMi erased programs,cannot use eRecovery
Click on Start choose Run and type in the box msconfig go to Startup tab un-tick the e-Recovery monitor
Feb 19, 2008 | Acer Aspire 9300 Notebook
ERecovery error
Sorry.I think u missing windows supporting files.Better to u format and reinstall windows.
Computers & Internet Logo
780 people viewed this question
Alun Cox
David Payne
David Payne
