Question about Samsung S850 Digital Camera
Help THE LENS IN MY CAMERA IS JAMMED AND MAKES A BEEPING N, ISE AND THEN SHUTS OFF. CAN IT BE FIXED?
  • Anonymous Jun 24, 2008
    exact the same
  • Anonymous Dec 02, 2008
    help me =[
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Feb 27, 2013
SOURCE: Samsung camera power-on problem and beeping
Camera got dropped..had the same problem here, looked after reading this and the smallest part of the telescoping lense was just a little tilted. Gently moved it out and popped it back, works fine now. Another thank you for the tip!
Posted on Dec 24, 2007
  • 4 Answers
SOURCE: help
Try Energizer rechargable nimh batteries with 2500 mah. I had the same problem and using these batteries solved the problem.
Posted on Jan 15, 2008
  • 11967 Answers
SOURCE: lens wont come out to take picture
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 05, 2010
  • 11967 Answers
SOURCE: telescopic mechanism for lens has jammed flush
Posted on Feb 26, 2010
SOURCE: the shutter lens to the Samsung Digimax S500
This normally happens when the batteries are going flat. Replace batteries and the problem should be solved.
Posted on Jan 24, 2011
My camera says lens error and shuts down
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Jul 17, 2010 | GE A730 Digital Camera
When power on get lens error and camera shuts off
May 25, 2010 | Pentax Optio 60 Digital Camera
It shuts off after turning on and the lens will not retract makes a grinding sound then shuts off
It seems that the one of the gears of your lens has came loose that is why you are expiriencing the problem. This may happen if the camera has been dropped or the lens has been banged.
You should contact the companies repair center to have your camera fixed
Nov 03, 2009 | Kodak EasyShare DX6440 Digital Camera
Lens error message and camera shuts down
Aug 09, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Makes clicking noise when turned on than says error and shuts off
your lens are jammed there could be dirt trapped inside try to tap the sides lightly and then turn on.
Mar 08, 2009 | Casio Exilim EX-S600 Digital Camera
Lens jammed with sand
This does not get fixed - throw it away and buy a new one.
Aug 03, 2008 | Olympus FE-280 Digital Camera
Lens do not open
More than likely lens is off track. send into casio to have it fixed.
Oct 19, 2007 | Casio Exilim EX-S600 Digital Camera
Lens opens and then gets stuck
I just had this same problem. The lens came out all the way, but then make a crazy beeping and clunking sound. The LCD would not come on. I took off the casing, and the clunking sound was coming from the mechanism that has gears in it, and seems to be what makes the lens come out. I tried blowing canned air into it, and banged it around, but nothing worked. Then I pulled a little too hard on the lens and accidently pulled the whole lens off. Oops. Looks like a new camera for me. So my solution is: don't pull on the lens.
Sep 19, 2007 | Casio Exilim EX-S500 Digital Camera
Camera beeps twice and then shuts off. Does let me look at pictures.
You have a "lens error". That is something that can only be fixed by sending it into Casio. I would call them first and they will tell you everything that you would need to send in. Their number is 800-706-2534 and then keep choosing option 1.
Jul 07, 2007 | Casio Exilim EX-Z57 Digital Camera
Samsung S850 Digital Camera Logo
21 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
