Question about Sony Cyber-shot DSC-T300 Digital Camera
It vibrates once turned on - Sony Cyber-shot DSC-T300 Digital Camera
  • 87 Answers
On Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
i have a document with pictures explaining the process
Posted on Dec 20, 2010
After charging my headset it will not work all it does is vibrate
Does it ever vibrate? Like if you power off completely, then power back on, phones that can vibrate will usually vibrate once as you see the bootscreen appear.
Or how about the keyboard? Does the vibration work with each keypress if you have that setting turned on?
If none of these work, then it is likely that the vibration motor is broken. Remember that it's essentially the only moving part inside the phone, so it's not surprising that it is prone to breakdown.
Mar 24, 2016 | Radio Communications
Ford focus 2004 vibrates when cold and right turns , once the car worms up the vibration calms doun
Hi
Is this engine vibration? if so then I would check the air mass sensor, they start to do this when the car is cold and ofetn are fine once the car is warm. You can remove the air mass sensor and clean it up with carb cleaner, this normally fix's them but not always, certainly worth a try before buying anything.
They are easy to remove and refit, let me know if you need any help.
Is the cars revs / rpms rough when cold?
If so then most likey it will be the air mass sensor/air flow sensor.
Regards
Dan
Feb 13, 2010 | Ford Focus Cars & Trucks
How to stop Vibration at sciphone i9+++ mobile . please help
pls clarify more ... but i think that is a similar problem. proceed to phone settings and set off the vibration. or changed your message/ringing tone to BEEP ONE . the vibration will come out once
Sep 03, 2009 | Dual Electronics CECT P168 Cellular Phone
Whenever I turn on my car there is alot of vibration from engine
bad engine mount make car shake.cylinder misfire make engine shake.
May 10, 2009 | 2000 Mitsubishi Eclipse
Dash does not vibrate??? anyone help
It does vibrate! All you have to do is hold down the # button for about 3 seconds and the let it go. The phone will vibrate once, and then it will have the "vibrate" icon at the top of the screen to let you know that it's on vibrate. To turn it off of vibrate, hold down the # again for about 3 seconds. Hope this helps!
Mar 08, 2009 | T-Mobile Dash Smartphone
Motorola T6550 pair.
I can see where this feature can seem somewhat inconsistent. But if you think of it like a phone ringing, it is easier to understand. Once you have answered the phone, the phone stops ringing. And the person who called you never experiences a ring on their end.
VibraCall® Alert
Page 26: VibraCall is a vibrating alert that notifies you that your radio is receiving a message. This is useful in noisy environments. When the alert is on, the radio
vibrates once every 30 seconds when you receive a message on the channel and
code you set.
• To turn vibrating alerts on, press menu until the vibrating radio symbol is displayed, then press the plus (+) button to display the letter Y for Yes.
• To turn vibrating alerts off, press menu until the vibrating radio symbol is displayed, then press the minus (-) button until the minus symbol (-) is displayed.
Dec 10, 2008 | Motorola Talkabout T6550 (7 Channels)...
Vibration only vibrates once
You will have to change the ringer under sound settings to "Vibrate and Ring", it is currently set on "Vibrate Then Ring".
Hope this helps,
Simon.
Oct 23, 2008 | LG VX8300 Cellular Phone
Vibrating won't stop
hi if u find that problem just hit once back of ur phone in ur palm hit smoothly....
Jan 13, 2007 | Nokia 3230
VIBRATING ALERT DOESNT WORK
Open the unit and clean the contact on the vibra and check the vibra to see if its stil ok. Use an eraser to clean the contact.
Jul 24, 2006 | Nokia 3220
Sony Cyber-shot DSC-T300 Digital Camera Logo
143 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
