Can a broken cd disk tray be fixed on a pc - Computers & Internet
    Problem Solver:
  • 6 Answers
Hello!
Yes,A broken CD tray on a computer can be fixed on a PC,i recommend(If you still have warranty) to send it in,At home fixing might be a little more difficult and probably not worth it.
Depending on the model and many other factors and not being able to see the damage its hard to say.If you dont have warranty,sending it in to repair might be just as expensive as buying a new drive completely!
Hope this helps!
- AriGold
Posted on Nov 04, 2010
Says mechical error when trying to open disk
Drive is no good. Use a straightened paper clip and insert into tiny hole in front of cd tray to open tray and remove any disk in there. Then replace drive or try to fix the drive.
Apr 09, 2016 | Computers & Internet
My cdplayer felease button is broken how do i fix it
Most CD/DVD players have a tiny hole somewhere near the release button. If you straighten a paper clip and poke it through the hole, it should release the tray and you get the disk out. I doubt you can fix the release button, but someone here may know.
Jan 15, 2014 | Panasonic portable cd player SL-SW505 User...
Lenovo Z570 Disc tray is stuck -outside of laptop
Open the try slightly, shut down the machine, tilt the machine to the side of the DVD/CD drive a gently shake to loosen the tray or whatever is causing the problem, Is the disk off the spindle? Is the dvd/cd broken? Can you insert something to clear whatever is obstructing it? Have you tried to eject using the software, Go to computer, right click DVD/CD rom drive, click on eject? Has there been any damage to that area, bent..etc? You may have to force it open or remove the drive and try to open it.
Nov 19, 2012 | Lenovo Computers & Internet
A disk is stuck in my Harmon Kardon player. The door will open and close and I can see the disk but cant' get it out.
turn on the unit and then tried to press the play button while the cd tray is in place. if doesn't work, unplug the dvd player then open the cover to access the internal part. look for a broken limit switch for cd tray mechanical assembly or check weather the cd not in proper place in the tray that is why an error occur.
Sep 02, 2012 | Televison & Video
CD-R drawer won't open. CD is in drawer.
there are different reasons for stuck up disk tray
1. load belt is worn out already
2. driving gear for mechanical loading disc tray has broken teeth.
3. cd got stuck up between the loading disc tray and the plate holder.
You will need unplug your device first and then unscrew the cover of your unit and find it yourself to know what causes it not to open.
once the cover is out, the mechanical loading disc tray will be exposed.
1. remove the stuck cd
2. plug the unit and turn on, to get access the belt, wait for the disc tray to move to the pull out position, then unplug your device.
3. plug the unit and turn on, if the disc tray do not move, use your finger to move the tray and see which gear is broken.
belts are available from this site. just have to measure the correct diameter of the belt in your unit
http://electronics.mcmelectronics.com/search.php/ui.php?lastSearch=belt+cdr201&lastDims=4294967285&Ntt=belt&ctl00%24ct1%24RefineButton=Refine
Feb 16, 2011 | Classic Electronics CDR201 CD Recorder
Dear sir i have a compaq prsario desk top having vertival mounted cd drive. i tried to load small cd on this but it got stuck and cd drive is partially opening and the cd is not coming out. wat am i todo?
place the computer in a position in which the tray will be horizontal ..after that take a look near the tray it is a hole in which a sharp object inserted will open the tray manually ..in case it is not opening from the eject ...and remove the disk ..
if the disk will not remove ...turn the computer upside down but the tray to be in same horizontal position ..This happens cause the disk is not staying in place .....and the tray being in horizontal position and upside down..the disk will come out when the tray is opened
Jan 11, 2011 | Compaq Computers & Internet
New computer (1 month old). Worked fine until today. When tuned on, screen won't come on, and CD disk tray won't pop out.
Since your PC is a new set, best for you to do is to send it back to the vendors to have it fixed. If you open up the casing & the seal is broken your warranty will be void, thus you will not be able to claim warranty from hp.
Hope it helps.
Dec 03, 2010 | HEWLETT-PACKARD Hewlett Packard HP...
My Xbox 360 stopped spinning the CD and playing the games.
i myself have the same problem and currently working on it. go to youtube and type in "how to fix a broken xbox360 dvd disk drive" this guy is amazing and helped me out with the red rings of death. all u have to do is buy a new disk drive for about $50 and take some parts apart.
Mar 14, 2009 | Microsoft Xbox 360 Console
CD ROM is jammed-wont open
This has happened to me. Sometimes when I'm in a hurry I'll place a CD or DVD in the tray and start to close it without making sure that the disk is seated flat in the tray. If it's ****-eyed the CD wil shatter when the tray is closed. The only way to remove the pieces inside the CD drive is to take apart the CD drive. Might be easier just to replace the unit. They run from about $25.00 to $75.00. One other note: You can try to open the tray manually by inserting the end of a paper clip into a small hole on the front bezel of the drive.
Oct 17, 2008 | E-Machines emachines (emachinees) CD-ROM...
Disc tray rattles
the screws on top of the disk tray may be loose u can take it in or fix it yourself if u dont mind takin your ps2 apart or have already just make sure screws on top of disk tray are tightend down all the way its an easy fix but be doing this it voids warranty and i i think that if seal on back is broken u cant take it in to have it fixed.
Jan 02, 2008 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
Alun Cox
David Payne
David Payne
