Dear Sir I have a Siemens Aquastop 8kg. extraklasse, S 14-79 the cycle is finished and the front door does not open, I pulled the red plastic which is infront right hand side, but still does not opem, what to do? please help. BR. Moses
  • moses215 Nov 04, 2010
    Dear Joe
    I tried both suggestions it did not work, the door still does not open.
    Moses
  • 10,865 Answers
Hello. Unplug the appliance or kill the power to it at your home electrical panel for five minutes. This will cause it to reset and may alone allow you to open the door again. If the door is still locked reset the controls as if you were going to start a new load of clothes as this may allow you in. Joe
Posted on Nov 04, 2010
  • 15,935 Answers
What is the model # of the unit please?
Thanks!
Posted on Nov 12, 2010
How to unlock washing machinge
Question is somewhat ambiguous, since in normal operation the door "unlocks" when the cycle is finished and the orange DOOR button is depressed. To manually open the door mid-cycle or with no power, find the yellow plastic tool attached to the soap tray and use it (or something similar) to pry open the front access panel at bottom left. There will be a plastic ring projecting downward into the cavity behind this panel: pull it sharply downward and the door should open.
Jul 11, 2014 | Miele Novotronic W1918A Front Load Washer
Siemens Dishwasher flooded. Now it doesn't take in any water and does not finish program. Aquastop filter?
Typically all dishwashers have a maximum full switch that is located on the bottom of the inside of the washer, on some it looks like a round plastic cap about two to three inches round, if you grab it it will move up and down as much as a half inch, this is a float that when the water level is at the maximum will turn off the water inlet solenoid, I have had something small (in my case a small lid) get under this float holding it in the up position so it would not allow the washer to fill with water, after removing the lid the float went back to the correct position and everything worked fine. I would say this is happening to you by what you say has happened.
Nov 12, 2013 | Siemens Dishwashers
F 16 AND F 63
F16 occurs when you try to start machine with door open or faulty door lock, F63 is a fault with control module
Mar 22, 2013 | Siemens WM14S794GB Front Load Washer
How to open the door of the siemens iQ300 washing machine
This problem has nothing to do with water in the machine. My IQ300 regularly refuses to open on the drying cycle! You have to open the small round compartment beneath the door and pull down on the black plastic strap to the right - you may need a utensil to pry it out. What a rubbish machine.
May 29, 2011 | Siemens WIQ1633 Front Load Washer
I have just purchased an 8KG Siemens front loader
Time to call the selling dealer for warranty service.
Aug 01, 2009 | Dryers
Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
Aug 30, 2008 | Hotpoint WMA40 Front Load Washer
LG WD-1295FB : Door doesn't unlock
open the access panel on the front by sticking a nail in the hole and popping it open, and inside the area you will see a thin white plastic pull tab that goes up to the latch. Pull this down and pull the door open. it should open very easily, if not make sure you are pulling the tab all the way down
Apr 29, 2008 | Washing Machines
Siemens 1433 Washer - Aquastop
I had the "pump blocked" message, and we had the pump replaced after the technician took a look. He said the washer had been overused (we had run it 4 times a day for 8 months).
Jan 13, 2008 | Siemens WIQ1433 Front Load Washer
Washing Machines Logo
275 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
