Question about Zanussi F1045W Front Load Washer
DOOR CATCH BROKEN - HOW TO OPEN DOOR FROM INSIDE THE MACHINE
Hi my Zanussi F1045 front load washing machine door handle has broken and is loose to pull and it does not open the door from the outside.
If I take the top cover off the machine, can I open the door from the inside as I have clothes trapped inside.
Regards
Peter
  • 3 more comments
  • Hitension Jun 13, 2008
    Hi Thanks for that. But I already have the user manual. The handle has actually broken and I need to release the door from inside the machine - I am awaiting a new handle assembly.
    Cheers
    Peter
    Hi Thanks for that. But Zanussi does not appear on this link page.
    Cheers
    Peter
    the only covers that can be removed on this machine are top and rear -it is not like the illustration on your link.
  • Hitension Jun 14, 2008
    surely there must be an easier way!! - the service man opened it by putting his hand in from the back according to my wife - but I cannot see how he did it - looks just like a housing at the rear of the catch and I cannot feel anything - I just wanted to be able to complete a few washes before he comes back to repair it in a couple of weeks - part on order.
    I have had the lid off and can see the catch assembly and had a feel around, unfortunately nothing obvious that looks like it can be operated - all surrounded in plastic - I think we'll give it a miss thanks as I assume you don't know about this particular machine?
    Cheers
    Genius:
  • 1,665 Answers
Select washing machine at link below to find door handle
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Jun 13, 2008
    Master:
  • 555 Answers
A manual for this washer can be found here.
Unable to open door
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jul 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
UNABLE TO OPEN DOOR AFTER WASH
Apr 08, 2010 | Hotpoint Aquarius WD640 Front Load...
Broken machine door handle :(
Unplug at the mains, remove lid and door catch can be released from inside the machine.
Sep 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Hi We have a Zanussi Turbodry and when i tried to open the door it wouldn't move and i have now broken the handle off!!! How do we open the dooe?? Thanks Lynsey
Get a thin screwdriver and poke it in between the door frame and the front of the washer where the door latches in, push hard and see if it will release that way..
If no go, then remove top of washer , and with a long screwdriver or similar try to release the door catch from inside the front of washer, you may have to lever it open, and possibly break the door lock in the process.
There really is no other way of releasing door.
You obviously will have to replace the whole door handle assy, and the door lock.
Plz rate my solution.
Thanks.
Jan 18, 2009 | Washing Machines
Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Jan 29, 2008 | Washing Machines
LG 1480fhd
Try first to unplug the power cable and see if it allow you to open the door. In case it will not help, you have to raise the top of the washer to get to the switch and release it manually (The switch is inside the washing machine main housing near the door frame). Good luck
Sep 03, 2007 | LG WM-1480FHD Front Load Washer
Door latch broken, clothes stuck inside!!
not that easy. best way to try is to chew away as much of the handle as possible till the door peg is in view then prise open with a small screwdriver. you can sometimes reach down the inside the machine from the top and feel for the tip of the peg and do it that way
Apr 01, 2007 | Zanussi FLA1001W Front Load Washer
Problem with washing machine
New door sensor im afraid,unless the machine senses that the door is properly shut none of your wash or spin cycles will start.Sensor located inside washer casing , where lock pin on door handle enters machine.It may just be loose,try tightening the two screws either side of lock keep.If it needs replacing you will need to UNPLUG washer ,remove lid and slide your arm down inside front of washer to access.Good luck.
Oct 23, 2006 | Zanussi FLE1416W Front Load Washer
Broken interior Door catch
You should open machine's upper panel (release 2 screws in the machine's back and slide the cover out) and then you will have an access to it. You should buy a new door catch and replace the broken one. Be aware that you should disconnect machine's power cable before doing it. Good luck
May 09, 2006 | Zanussi WJD1457W Front Load Washer / Dryer
Zanussi F1045W Front Load Washer Logo
486 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
