Where is the thermal fuse location on a Crosley dryer, model # CDE6000A? I have both the High Limit and Thermal Fuse, I know where the High lImit Thermostat is located, I just need help with the thermal fuse location.
I have an LG gas dryer DLG25232. It tumbles and blows air, but no heat. I have cleaned all venting, but not I believe I need to replace my thermal fuse, could you please tell me where it is locasted?
Where located fuse
The thermal is on the heater box on the right side it has two white wires going to it
you need to remove the high limit stat and bracket and the heating element to get to the safety stat
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
In Stock
Quantity:
http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
it is right below the other one, its a bit smaller and enclosed if I remember right
where is the thermal fuse located
