Question about Minolta magicolor 2400W Laser Printer
New Drum Purchased a new drum but problem still exists. Toner still appears on the new green roller.
    Champion:
  • 214 Answers
Clean laser unit glas, if you remove toners and pc drum, you'll see a piece of class under them, clean int and reinstall.
Posted on Jun 19, 2008
Streak in the middle of the copie/print with drum and blade replaced
Please clean the drum charge roller use the izopropilalcool,clean the charge roller cleaning roller,clean use the vacuum cleaner the waste toner (located under transfer assembly 6 screw),activate the ATDC and AIDC sensor configuration.
Jan 08, 2012 | Ricoh Aficio 1035 Copier
I am getting a faded line of text horizontally through the page. I tried new toner but this is not working.
Had a similar problem. The following solution from the Brother site seemed to fix it.
  1. Gently wipe the scanner window with a soft dry cloth. The scanner window is located on the roof of the inside of the printer.
  2. On the top of the drum unit (DR400), locate the blue tab on the left side. Slide it back and forth across the drum about 30 times.
  3. Remove the toner cartridge (TN430 or TN460) from the drum unit. To remove the toner from the drum: hold down the blue lever on the right side of the drum and lift the toner off of the drum unit.
  4. Inside the drum unit there is a green roller. Wipe the green drum roller with a dry tissue (i.e. Kleenex). You may turn this roller by moving the gears on the far left side.
Jan 16, 2011 | Brother HL 1440 Laser Printer
Our fax machine has been saying replace drum for a while and faxes have been getting darker and darker we cleaned it but now we can send but not receive what is the drum?
the drum is green roller in housing with toner, you should order the drum cartridge for your fax. With new drum you get the how to manual also. Follow the procedure.
NOTE THAT THE DRUM UNIT IS SEPARATE FROM TONER UNIT.
Hope that helps!
Oct 19, 2010 | Panasonic Panafax UF-490 Plain Paper Laser...
Our Kyocera FS2000D has two small parallel lines down the left hand side of the paper. It just started doing this. Is this a symptom that the machine needs a new drum? How hard is it to replace the drum?...
drums are very easily to replace.. you don't even need a screw driver....before you order a drum...check the charge rollers..
this roller is part of the drum and you can order it seperate...
ok.. to remove the drum..first take out the process unit..this is the entire unit that the toner sits into( don't unlock the toner)..once the process unit is removed..open the left hand cover and remove the waste toner bottle.. the drum sits right above the bottle..simply push on the grey square tab.. to release the drum out of the left side of the printer (easy right!!) check the drum and chare roller..also on the process unit there is a green tab you can slide back and forth to clean the grid
Jan 07, 2010 | Kyocera FS-2000D Laser Printer
Printed sheets come out with blackish/greyish lines on the right side
Use follow these cleaning steps for your printer:
1. Open the front cover of the printer and remove the drum/toner unit.
2. Gently wipe the scanner window with a soft dry cloth. The scanner
3. On the top of the drum unit, locate the blue tab on the left side.
4. Remove the toner cartridge (TN430 or TN460) from the drum unit
(DR400). To remove the toner from the drum: hold down the blue lever on the right side of the drum (DR400) and lift the toner (TN430 or TN460) off of the drum unit.
5. Inside the drum unit (DR400) there is a green roller. Wipe the green
6. If the pages area gray pages or have gray vertical lines, install a
brand new toner cartridge. If pages have dots, spots, smudges or
horizontal lines, install a brand new drum unit.
OR
If you are still experiencing gray pages or gray vertical lines,
please install a brand new toner cartridge (TN430 or TN460).
Brother strongly recommends that customers do not use generic drum unitsand/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability.
The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | Brother HL 1230 Laser Printer
Put in brand new toner machines says toner is low.
plull the drum out...and clean the roller....you will be able to see the ink on the roller where your lines are appearing.
Jan 13, 2009 | Brother IntelliFax-2820 Laser Fax
Vertical Stripes on printed Page, Shaken Toner, Relatively new Belt (Green thing), cleaned the fuzer wire, cleaned the cleaner roller, has oil.
Depending on the type and model of your printer this could be several things mostly related to the cartridge or drum if you have a separate toner/drum system.. Since you have stated you have shaken the toner, I am assuming you have a laser printer. New belt, has me confused. Green thing leads me to think you are talking about the drum. If so, did you purchase a new toner cartridge or new drum cartridge?
Several components inside the toner or drum cartridge will cause vertical streaks. It depends on where these streaks are occurring and how wide the streaks are. We call these repetitive defects and they can be measured to determine which part is at fault.
Also, if this is a multi-unit machine (print/copy/fax/scan) Check the platen glass or ADf feed unit for white out. That has been a major culprit of vertical streaks on the page.
More specifics about the model of machine and cartridges being used would be helpful in trying to solve this problem for you.
Nov 14, 2008 | Brother Office Equipment & Supplies
"Please change PC Drum" message appear on printers LCD
If your print job prints ok, ignore it. Just bear in mind you'll need a new drum soon. The drum is a light sensative roller that ink from the toner cartridge adheres to where the laser hits it. When it is no longer magnatized enough to hold the toner you'll see your print jobs start to lose that toner color. Just pull the drum out, buy a new one and put it in. Just don't expose the drum to light very long.
Oct 24, 2008 | Minolta Di2510 All-In-One Laser Printer
HL-2040 CHANGE TONER
I just had the same problem and fixed it. Hold down the blue "go" and red "job cancel" buttons at the same time for a few seconds. The printer churns into action and the green status light goes on. I was able then to print.
Dec 30, 2007 | Brother HL 5040 Laser Printer
Black spots on my documents Brother HL-1440
Stray dots (on a vertical imaginary line on the page) may not require an expensive drum replacement. In my situation, I simply followed these steps:
(1) Open up the printer, remove the toner-cartridge/drum assembly, and remove the toner cartridge from the drum.
(2) For purposes of reference, place (and center) a sample page of the "offending" output in the bottom of the drum housing, lining up the dots so that the page is turned the way it would have fed through the printer, placing the page generally in front of the shiny green roller surface. Loo, for where any matching black dot or other thing might be sitting on that surface.
(3) Gently roll the green surface's roller with its outside end pegs (without touching the green surface) if and until such a matching dot (or dots) can be found. (Multiple dots might appear along other imaginary verticals on the page, which is to say, additional vertical striping is occurring because there are more instances of "items/dots/garbage" arrayed across the roller on the horizontal, to produce repeat images down the page as the page feeds through the printer.)
(4) Take a Q-tip and very, very, very gently "polish" away the dot(s) you found on the green roller. (I ended up just dabbing the dot I found--which had consistently left a trail of three dots down my pages, in different locations because of the distance the roller traveled relative to the page size--using the absolute least amount moisture to remove it.)
(5) Clean the drum's corona wire by moving the blue plastic slider back and forth, and leave the slider at the far left point.
(6) Reassemble the toner cartridge and the drum and place the assembly back in the printer.
(7) Test.
Worked great for me. Done in around five minutes. No cost, except for the negligible cost of a Q-tip. No time waiting for a new drum to show up, etc.
Oct 17, 2007 | Brother HL 1440 Laser Printer
Minolta magicolor 2400W Laser Printer Logo
210 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
