Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
I have a John Deere model 3020 tractor. When the ignition is turned to the 'running' position the coil on the back of the key ignition swith, glows orange hot. This occurs within less than 60 seconds whether the engine is running or not. By orange hot I mean the color is orange (from heat) and is much to hot to touch, as it will cause blistering to the skin. This of course continues as long as the engine is running or the key is in the 'on' position. Is this heat normal. If not what is the problem. I have replaced the ignition switch and the female spade connectors on the wires which connect to the switch.
  • John Deere Master
  • 7,515 Answers
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Posted on Apr 14, 2017
2 Suggested Answers
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
Where the thermostat for the glow plugs on a 6130D John Deere tractor located
no thermostat for glow plugs
there is a relay that turns them on when the key is in the correct position
Dec 16, 2017 | John Deere Garden
How do I change the fuel filter on my 3020 John Deere diesel tractor
Leaving the fuel valve on the tank in the on position will allow fuel to run through the line & keep the air purged during removal. On the other side between the pump & the filter, having the new filter topped off & speedily installed will lessen the chance of air entering the line. Once the filter is installed, open the bleed screw at the top of the filter. Just my redneck way.
Oct 05, 2014 | John Deere Ar50041 Diesel Fuel Filter 3020...
John deere 110 engine cranks but no spark
Check that the ignition coil kill wire is not shorted to the frame.
Check coil to flywheel gap. A business card between coil and flywheel will set correct gap.
Coil could be bad or ignition switch is not releasing the kill wire in Run/Start positions.
Nov 03, 2013 | John Deere Garden
Remove spindle john deere 3020 tractor
Remove bolts or clamp on top of spindle. Next remove steering tie
rod. It should slide out.
Sep 26, 2012 | John Deere 3020 Gas & Diesel Tractor...
No spark to spark plugs on john deere 2510
do you have a bad wire or a bad wire going from the points to the coil
Jul 28, 2012 | John Deere Step 2510 2520 3010 3020 4000...
John deere model240 mower will not start. Have replaced coil and still not getting spark at the plug . Engine turns over strong
Only option left.... 12 volts feeding coil is not there. The ignition key applys the 12 volts to the coil in the "Run" and "Start" positions. Verify 12 volts at input to coil and then (if needed) follow wire back to key and confirm voltage there....and (if needed) follow input wire to key from battery. One of those critters is open - since you have already confirmed the coil/spark plug wire is not at fault.
Dec 15, 2011 | John Deere Garden
We fixed an engine of john deere 3020 diesel model 1966. All things it's ok. We took a watch which pressure the oil engine instead of the short lamp. When the engine is working and is cold, the pressure is...
I have been working on the my John Deere 3020 and can not get it to start. I had the starter rebuilt and have gone through everything I can think of! Any help would be great
Feb 18, 2011 | John Deere 3020 Gas & Diesel Tractor...
Jul 04, 2009 | John Deere 3010,3020 Tractor Basic...
John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
330 people viewed this question
Top John Deere Garden Experts
Dave
Jim Parker
Jim Parker
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
