Question about Whirlpool Washing Machines
Washing machine spins but doesnt drain water until I turn it back to spin only
I have a Whirlpool Gold Ultimate Care II Heavy Duty Super Capacity Plus washing machine. Everything works fine except when it does the spin cycle the water does not drain. Here's the catch; when the cycle is done it is full of water and I dial it back to spin it goes spins and drains the water. And only on the normal cycle, all other cycles drain properly but the normal cycle is the one I want to use cause it aggitates more. So if I do a load of laundry and the cycle is over I have to manually turn the dial back to spin to drain the water extending my wait time. Whats wrong?
  • Anonymous Mar 30, 2014
    Pumps water and drains, but qouit spinning
  • 1,073 Answers
Timer contacts are burnt replace the timer
Posted on Jun 13, 2008
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
  • 278 Answers
SOURCE: ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Posted on Oct 16, 2009
  • 10865 Answers
SOURCE: Find serial and model number
Hello. for a top loader look here
  • Under the lid
  • On the back of the control panel
  • On the lower-front or side of the main cabinet body
  • Posted on Apr 30, 2010
    • 8220 Answers
    SOURCE: Ultimate Care II washer will not agitate or spin
    Your lid switch could be the problem. It has 3 wires: black red which are hot and green which is ground. Unplug that lid switch and check for continuity between black and red with the lid shut. This video shows where the lid switch is located
    Posted on May 08, 2010
    • 5911 Answers
    SOURCE: water leaking during rinse cycle
    If your TOP LOADING Whirlpool washer is leaking, the following link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak:
    If the leak is more like a constant drip, a common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
    Don't forget to check all drain hose connections under the washer and the center tub seal.
    Replacement parts (if required) can be purchased at any of the following websites:
    Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
    If you have any questions, please post back and let me know. I hope this helps you.
    Posted on Jul 05, 2010
    My whirlpool ultimate Care II Heavy Duty Super Capacity Plus washer Very slightly agitates and don't spin dry
    The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
    Mar 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care Heavy Duty Super Capacity Plus
    clutch could be it check if nothing is jammed between tub andbasket. if u have an oily tranny i would replace it
    Feb 12, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
    Old Washer won't spin or agitate
    You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
    Feb 15, 2009 | Whirlpool Washing Machines
    Washer spin & gurtitate no working
    Coupling is broken that connects motor to transmission. Replace it. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
    Nov 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Won't spin or agitate
    coupling.between motor and gearcase.
    Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
    Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    754 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
