Question about Freezers
The Fridge stays too cold at -6.
The Fridge side is -6 and the freezer side is -15. The controls do not seem to work. What test can I do to find out what is wrong. Is it the thermostat?
Tony at email trancesleep@msn.com
It is a Whirlpool side by side fridge freezer. Model 3XEC5THGKBOO
  • 2 more comments
  • Ratkins Jun 16, 2008
    Thank you 22yooper.
    I am a plumber by trade, is changing the thermostat easy to do?
    If so, is it at the top of the inside of the fridge in the control box?
    Regards
    Ratkins
    Thank you 22yooper
    Is the thermostat found in the inside of the fridge at the top inside the control box.
    Cheers
    Ratkins
  • Ratkins Jun 17, 2008
    Thanks for that, your information is really good. I will give this a try, it can't be too difficult.
    I will let you know how I get on.
    cheers
    Ratkins
  • Ratkins Jun 18, 2008
    Fixed, thanks to 22yooper
    Inside the control box in the fridge there is a rectangular valve. This valve is opperated by the thermostat. The valve its self was broken and therefore not closing the hole between the freezer and the fridge.
    A bit of superglue and we were away. fixed
  • 828 Answers
Yes it is the thermostat. Replace it or have it replaced.
Posted on Jun 15, 2008
  • James Helmer
    James Helmer Jun 16, 2008
    Yes, the control for operation is in the refrigerator section. Usually located right behind the temperature adjusting knob. Should not have to force anything. Remove the old control and install the new one in reverse order.
  • James Helmer
    James Helmer Jun 18, 2008
    Good man.
Freezer works fine but sides get really warm
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
May be overworking itself to stay cold
Sep 05, 2014 | Kenmore Freezers
Fridge not working but freezer is ok fridge light works
There is probably an ice build up between the two sides of the appliance. There may also be a problem with the damper unit which controls the cold air coming from the freezer side to the fridge. The fridge is controlled by the freezer. Dependant on appliance. The door opens and closes letting the cold air go into the fridge and when the fridge is cold enough the door will close agin. This is not something that you will see happening it is normally concealed behing a diffuser.
Feb 24, 2010 | Freezers
My Maytag msd2756geb freezer is too cold.
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Feb 04, 2010 | Maytag Freezers
Freezer seems to be working fine but fridge is not cold... fridge is on top of freezer, it is a frost free zanussi, not sure which model thou, just coming up to 5 yrs old ? any help would be great thanks
A fan controlled by a thermostat is required to move the cold air from the freezer to the refrigerator for cooling. Use a volt meter testing the voltage on the fan. If you have voltage it is a bad fan. If you do not get a voltage test the thermostat. If it measures zero ohms short the thermal switch or if it is a short open one lead. If the fan works replace the thermal switch.
Sep 01, 2009 | Blueair Freezers
Freezer very cold, no air going into fridge it warm ANY SUGESTION
hi there,
check the blower fan inside evaporator,there is fuse on the back side of your refrigerator for cooling fan,check on this using multi tester if busted replace fuse.
Jul 06, 2009 | Maytag 15 cu. ft. / 425 liter Upright...
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Hotpoint rfa70 fridge seems not to be staying cold
just give it time as the freezer has to come down to temp first
Jun 05, 2008 | Freezers
Indest Fridge Freezer
Possibly something was spilled and it got to the door gasket. Clean the door gasket area with warm soapy water. In the door there is nothing critical to the system operation that should cause the condition you have.
May 17, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
139 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
