Question about Dishwashers
My dishwasher is not filling up with water?
GE dishwasher...it hums and heats but is not getting water. Please help. Texas resident
  • 796 Answers
If the water seems to be flowing in slow, I would turn off your water supply to your dishwasher, then disconnect your water line to your inlet water valve, then check the screen on the inlet water valve, its most likely clogged.
Posted on Jun 16, 2008
Dishwasher fills with water then hums
Hello & Welcome to FixYa
When the dishwasher fills then it means that the control and the water inlet valve are fine, hum sound itself indicates that the motor is bad and needs replacement. If you hear a hum sound from the bottom of the unit then it is the motor that is bad and if the hum comes from the control then it is the timer that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | KitchenAid KUDS50FVSS Builtin Dishwasher
DISHWASHER GE PDW7800J00BB DOES NOT WASH ,FILLS WITH WATER BUT NO WASH
It is unclear from your description if the wash pump starts and pushes the water around but never stops cycle or the dishwasher stops as soon as the water is filled.
If you do not hear the wash pump start then it is possible the wash motor is faulty. But if the wash pump starts and never completes the wash cycle then it is possible the heater is faulty and dishwasher is waiting for water to heat up before it can go to next cycle.
See the attached diagram for location of wash pump motor and heater.
Hope this helps you find the problem. Please rate the solution if you found it useful.
Oct 10, 2010 | GE 24 in. Profile PDW7800 Built-in...
My GE Potscrubber Dishwasher doesn't spray water when it is turned on. It has power.
If you turn it on and hear a slight hum after water fill the motor is locked from non use. You will need to remove bottom panel and with power off you will see the motor right in the middle near the front. This is called a side winder motor because of how it sits. There are some blades you can turn to unlock the motor. Once the motor breaks loose which you will be able to tell when it does, turn power back on and let run thru complete cycle with heat dry in the off position. GE are about the only ones out there that will do this and it is usually from lack of use. Hope this helps.
Feb 21, 2010 | GE Dishwashers
Running but not cleaning
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
Does not cleans dishes
Hi
Thanks
Rylee
GE model GSD600003 repair manual: Before you answer this, please tell me if I will be charged for the answer, in case I'm not interested at this time. Do you have a diagram of the drain area and water...
I'm not sure how mildew can grow in a dishwasher that is working well, but after cleaning it and putting things back together, it does now seem to be working. I thought that the water wasn't filling but I guess the heating element heats up before the water fills the dishwasher. So when I tried again and started the dishwasher from the beginning and waited, it did progress to filling water and going through the whole cycle.
Oct 18, 2009 | GE Dishwashers
GE diswasher hums but will not start cycle and starts to smell ho
Hi, Have your freind check and see if the water supply line under the sink has been turned on. The hum you are hearing could be the inlet valve. Please let me know if this has been helpfull or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | General Electric CDW9380N Built-in...
Washer fills, but cycle doesn't start
This is motor failuer. replace asap. the smell is the motors copper windings heating up the internals of the motor Housing.
Jun 02, 2009 | GE 24 in. GSD4030Z Built-in Dishwasher
GE Dishwasher fills with water but does not "spray water" on dish
Here are a few things that might help you out, first is you could have a bad heating element in your dish washer, when it fills with water it has to reach a certain temperature before continuing to the next cycle, next thing is you could have a bad thermostat, or your timer is defective.
Mar 16, 2009 | Kenmore 16522 Built-in Dishwasher
Asko dishwasher won't start, just hums and gets hot
Get this every few months - don't know the problem but we disconnect from unit and tilt the dishwasher and loads of stinky water spills out - from where I don't know. Then just **** all the water out of the drain bit with a chicken baster - primative but has worked every time so far. Keep trying to get water out until doesn't hum when switched on.
Dec 16, 2008 | Dishwashers
Dishwashers Logo
763 people viewed this question
Top Dishwashers Experts
