Question about Canon PIXMA iX4000 InkJet Photo Printer
Model ix4000: Changed ink cartriges and printing blue lines across every print
    Genius:
  • 1,148 Answers
Print alignment page in options and clean heads to,,hp website check also
Posted on Nov 04, 2010
  • 1,218 Answers
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Every other picture comes out with blue streak across the top
A manufacturers default of printing an allignment sheet after the jobs been completed. The reasons are to indicate to the user ink conditions that is available when any print after all is observed on the complementary printed page. The functionality of the print allignment page could be disabled by manipulating the printer menu functions. the process may require removing and installing the ink cartriges for the option of allignment to be manipulated.
Dec 04, 2010 | Sony SnapLab UP-CR10L Digital Photo...
Hi, (MX850) My blue ink has stopped printing. I
Performing Maintenance:
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
Step 1
Printing the Nozzle Check Pattern.
If lines are missing or if white streaks appear
Step 2
Print Head Cleaning.
If the problem is not resolved after performing Print Head Cleaning twice
After cleaning the Print Head, print and examine the nozzle check pattern (Step 1) again.
Step 3
Print Head Deep Cleaning.
If Print Head Deep Cleaning does not resolve the problem, turn off the machine and perform another Print Head Deep Cleaning after 24 hours. If the problem is still not resolved and if you are sure that the ink didn't run out, then the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
All the best.
Mar 11, 2010 | Canon PIXMA MX850 Multifunction Printer
Horizontal streaks across printed pictures
Did you run a clean heads from the menu?
Also there is a function to align the heads again as well on the Menu
Feb 17, 2010 | HP PSC 2410 All-In-One InkJet Printer
Need repair on a HP1055CM plotter in Toledo Ohio
it is all one assembly. You will need to call a technician.
Jan 06, 2009 | HP DesignJet 1050c InkJet Printer
Ink smears
You need to clean it inside, use isopropylalcohol witch is good for cleaning ink
Dec 07, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Problems with color prining
hi!!!!
perform maintenance and
try to clean up nozzles may be the ink
clog
or removed the cartriged and clean with alcohol
use cotton buds then placed it back properly
Oct 31, 2008 | Canon BJC 2100 InkJet Printer
Epson Photo R265 Lines every 2.5 cm
If its doing it on all types of paper despite of any setting on printer driver, chances are you are having a hardware issue with the product.
pls try this site: support.epson.com try use passcode; lock
only applies for US printers
pls dnt 4get to rate soln hope the site will help thanks
Apr 06, 2008 | Epson Stylus R265 InkJet Photo Printer
Faint white line observed on print
nope, the TONER OR INK CARTRIGE is running out in tat area, so you have to check it so that there is a new one. hope this helps. :)
Dec 08, 2007 | Minolta magicolor 2350 Laser Printer
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
Will not print black
first of all the most important auestion is have you used compatible ink cartridges or genuine ones, because the print head clogs up with compatible ones, i really doubt that the cartridge you installed is damaged because i haven't come across this and i am a canon technician, i know this model well
Nov 02, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iX4000 InkJet Photo Printer Logo
203 people viewed this question
old marine
old marine
