Question about Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet is giving me a "F/06" error. It
  • 347 Answers
F/06 is a tachometer error for the drive motor This error code is a very difficult to diagnosis unless you are their in person to check the many things that need to be checked to properly diagnosis this concern. It involves checking the drive motor and tachometer the motor control board (computer) the machine control board (computer) ,and all wiring harness in between in other words this is where you need a highly qualified tech for a proper repair unfortunately. Of the one's I have diagnosed 80% were the drive motors the tach is made onto the motor and is not available separately,THE OTHER 20% where all the other items i mentioned. I truly wish I could help you more but this error is one that needs hands on testing and anyone that tells you different is incorrect and would just be guessing ..But if you want to try you can get a motor for about 165.00 and the motor control board is about 230.00 the good thing is you wont need both and if it's wiring you wont need either one. SORRY I could not help more Good Luck
Posted on Nov 04, 2010
Whirlpool duet front load washer with F 06 error message
could be control board, in the past this has been an expensive error code to diagnose
Oct 29, 2013 | Whirlpool GHW9150 Duet Washer
Whirlpool Duet washer - 4 years old- Error message F 24. It happened first during a "whitest white loads." Was able to re-start it and that load went through. Now it's happening all the time. ...
F24 Water temp sensor error. Failed sensor or heater. Remove your bottom panel and look for your tech sheet. It will give diagnostics and error codes. Manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 12, 2010 | Whirlpool Washing Machines
Whirlpool duet washer f-06 error
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. It appears that spraying the board and connectors work.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer shows error message "F 06"
Jan 29, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Can I get pictures/diagrams and instructions on removing the mcu board(duet ghwn150pw3) to check out f 06 error? Thanks
Please see the following Whirlpool Service Manual for the Duet Washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet F 06 Error
Remember that you don't want to do anything that would jepardize your manufactures warranty on parts and labor.
Nov 04, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
192 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
