Question about Samsung HP-T4254 42 in. Plasma Television
HDMI Cable problem
Hi
I purchased a Samsung 42" plasma and when I try to hook up the HDMI cable to it and set top cable box my tv says "Your HDTV does not support HDCP. Use the YPrPb components.
How can I get an HDMI cable to work?
I too have same problem wtf
Posted on Jan 28, 2013
Ever find a solution? I'm having the same problem
Posted on Jul 03, 2010
    Scholar:
  • 93 Answers
Well, first you might want to try another hdmi connection behind your TV.If it appears to have the same message,you need to check your TV setup and be sure the HDMI video is active.
Secondly,go with the recommendation of the set top box.You will use component video cable to connect from your set top box component video output(Y PR PB) to your TV (Y PR PB) and see if that actually work.If so,just use the cable box for the time being and call your cable company for another cable box to replace this one!
solutiondoct
Posted on Nov 11, 2008
How do you connect the cable to the tv? I have a dvr box but dont know where the connection on the tv is?
Cable from box to t.v , from antenna to box . If you have a hdmi cable plug into the back of the box, and plug into the hdmi input on the back or side of your t.v
Jan 17, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
Scrolling line
Question. Are the scrolling lines horizontal?
If so that is called 60 cycle Hum Bar and is a result of the following:
1. Bad grounding of the cable system.
2.Bad cable box. This a common problem with cable boxes.
3.If you are using Component cables from the cable box to the tv then the Component cables might be bad. Try using another set of Component cables. If that does not work then you need to call the Cable co. to come out and check their system and make sure that the cable tech brings out another cable box to try out. There is no problem with the set.
Jul 15, 2009 | Samsung HP-S4273 42 in. Plasma HDTV
No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
May 26, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Screen craked broken screen
Is it a Plasma TV? Are you saying the screen is cracked? do you have a top box cable box? Also, make sure you have your TV input set to HDMI if you have an HDMI cable hooked up between your cable box and TV.
Apr 04, 2009 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Can SPN4235 Support Blu Ray Signals?
After I got over my fustration I did a little more reading and discovered that I could use purchase a
HDMI to DVI converter cable. Since DVI, unlike HDMI, is video only I also had to purchase a digital optical (it also carries audio) cable to get sound. It cost me an additional $70 for the two cables but it was worth it. I reasonably happy with the 1080i resolution which is all my SPN4235 is capable of at least until I can afford a new 60" HD Plasma TV.
Dec 26, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Finding a set top box
Do you mean a freeview box? if so any freeview box will work via thw scart.
Nov 04, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Sep 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Aug 04, 2008 | Insignia 42" LCD Flat-Panel HDTV
Plasma
if your tv is on warranty take it back to best buy for a replacement.good luck
Apr 27, 2008 | LG 42PX5D 42 in. Plasma HDTV
Samsung HP-T4254 42 in. Plasma Television Logo
441 people viewed this question
Henry  Thomas
Henry Thomas
