Question about Amana DLE330RAW Electric Dryer
Dryer not geting hot - Amana DLE330RAW Electric Dryer
  • Amana Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101 ..
Posted on Nov 04, 2010
Hooked up roper dryer and it's propane everything seems to be hooked up right but won't get hot or even heat up. This is first time ever having to use propane. Any idea what it might be or could have...
1.is the pilot light lite burning.
2. if pilot light light is on ,does the blue flame of the pilot light touch and heat up the thermocouple.
the dryer will not turn on the heat if the pilot flame does not touch and heat up the thermocouple.
3 is the dryer plugged in to the electricity.
4. is the dryer actually getting electricity.
If the dryer has electricity and the pilot flame is touching the thermocouple, then try buying and installing a new thermocouple.
****have you purged the air out of the gas lines so that the dryer is actually geting pure propaine and not just air getting pushed ahead of the propaine.
how old is your dryer, if new, warranty service will trouble shoot & repair for free.
you need to tell us more so that we have some facts to work with. vagueness does not cut it.
Oct 09, 2013 | Dryers
1991 corvette is geting hot\
I had to clean the fan relay and works like a charm now....
Jul 09, 2012 | 1991 Chevrolet Corvette
Turning but not geting hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 13, 2011 | Kenmore Dryers
Not geting hot
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 31, 2010 | Whirlpool WGD5900S Gas Dryer
I have a sears dryer 417.90802990 which heats up but will not run..we had this problem before and replaced the themal limiter and it worked fine for about 1 month..same problem..replaced the thermal...
check that the intake air vents are clear it must be able to breath freely and that the hot air can get away freely this is the most comon thing to pop the thermal limiter,,the only other part that will blow the limiter is the heating coils if they are geting to hot becouse of a short in a winding
Jul 08, 2010 | Dryers
Maytag neptune dryer not geting hot
If your Dryer is the Electric version, then more than likely you have a burned out heating element, you can check it by first UNPLUGGING THE DRYER!!! after you have UNPLUGGED THE DRYER!!!, you can remove the front cover and check the element for continuity, the whole unit comes out as a Tube.
May 31, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Not geting hot
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Whirlpool WGD5820S Electric Dryer
Dryer geting to hot
When that happens it is usually because of a broken thermostat or a devective vent system, see : It overheats.
Nov 20, 2008 | Indesit W 123 Front Load Washer
Gas Dryer
Check tube belt or motor geting hot.
Nov 11, 2007 | Dryers
DRYER STOPS
could be thermal overload in motor its a motor protector in the motor when the motor gets hot it cuts power to the motor when motor cools it closes and resets age of drier counts some times you can take drier apart and blow dust out of motor and will fix now if the door is not closing tight vibration can cause door switch to break contact that will do it too most of time motor or relay must be replaced
Oct 27, 2007 | Kenmore 63942 Dryer
Amana DLE330RAW Electric Dryer Logo
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
