-   We have indesit IDL530 dishwasher which gets stuck on first 2 lights flashing sometimes soap released sometimes gets stuck but dishwasher will not go any further with programme.-   nathanjames
Dec 02, 2008
-   the machine starts up and i can hear the water inside then it stops, the 2 first lights flash and there is a couple of inches of water in the bottom which wont drain.-   gimbob
Oct 03, 2008
-   i have the same problem and have tried turning off the machine and removing the main power ,when the power is switched back on the machine seems to start up but after a couple of moments the same problem accures-   Guest
Best Solution
posted on Jul 13, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
no, turn the on / off button off, then turn off the power for about 5 minutes and then it should work again. and at some point do contact someone to look at it.
I am getting water leaking through the diswasher and have a large wet "seal" at the bottom...
(More)
I am getting water leaking through the diswasher and have a large wet "seal" at the bottom of the door. How can I stop the leak?
We have just aquired the machine with the house (no manual) The soap dispenser will not open when...
(More)
We have just aquired the machine with the house (no manual) The soap dispenser will not open when the machine is running. I'd be prepared to stop the machine and add the powder if I knew where in the cycle to do this. The other problem is that the dishes come out with fine grit dried on them. Should I just give up?!
My Indesit D63 won't start running. The power light comes on but then nothing. I've read other...
(More)
My Indesit D63 won't start running. The power light comes on but then nothing. I've read other solutions about how it's usually water draining in to the bottom of the dishwasher, but I've checked that. What I do have is where the salt goes in, there's another plastic section joined on to the salt container, but separated. This appears to be full of fat! I can't see how to open up the plastic container to remove this.
