Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My lift master garage door opener does not open or close, when you hit the button it makes an electrical niose for a few seconds and nothing happens. I checked the gears and they look fine. Any ideas?
    President:
  • 3,197 Answers
Is your door open or closed?
Posted on Nov 04, 2010
Lift-master 1265 Garage Door opener clicks but nothing happens
CHECK ON THE OPENER FOR A RESET BUTTON, IT MAY HAVE JUST POPPED.
Apr 10, 2013 | Sears Craftsman LiftMaster Chamberlain...
Master lift remotes suddenly won't work. Wired panel button works opening and closing door.
Make sure the light in the wall control is not blinking. If it is press and hold the lock button on the wall control for 3 seconds.
Feb 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
Lift master Garage doors the door doesn't close. once i press the button to close my garage door it shuts the door momentarily and then it opens right back up by itself. nothing is blocking the sensors.
Too much tension on the door can make the "brain" respond by opening the door, thinks something is in the way.... check for binding tracks or wheel guides, loose bolts, dry chain, tension on cables or springs ( be careful here), misaligned sensors....
Apr 06, 2010 | liftmaster Chamberlain Garage Door Opener...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Lift-master 2000SDR remotes will open but not close garage door. Same problem with all clickers and even those programmed into the cars. What could this be and better yet, how do I fix it?
Lift-Master 2000SDR opener. Opener generally works fine from the remotes. However, first time in the morning in cooler weather, it will start to close and the reverse and the lights blink. I have checked the senors - appear to be aligned properly. I have lubed the gear and used garage door spray on the rollers and hinges at the proper places. To close the door when this happens, I have to hold the wall button.
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears 1/2hp thinks it is not all the way up and will not go down
It is really a common problem for lightning or electrical surges to take out the logic board. Big expense too.
May 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Not working
IT MAY BE AGAINST THE TRAVEL LIMITER BOLT.
IF IT IS YOU WILL NEED TO UNPLUG THE UNIT REMOVE THE COVER AND TURN THE MOTOR BY HAND TO BACK OFF THE PRESSURE.
MAKE SURE YOU GO PAST THE LIMIT SWITCH.
ADJUST THE LIMIT SO TH DOOR DOES NOT HIT THE BOLT.
HOPE THIS HELPS
Sep 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
145 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
