Question about LG WM-2277HW Front Load Washer
LG wm-2277hw I have the same problem I have bought the part but i can't see where to replace it.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
If yours is the same problem, water in the dispenser, then the answer is the same...
The reason there is still water in the dispenser, and this in normal by the way, is the unit uses the pre wash and main wash valve to activate the fabric softener. Basically when the two valves come on they force water into the fabric softener compartment. There can be some overflow and it ends up in the blue cup nothing to worry about. Now if you have detergent there, then that is a problem..
Sgt 48
Posted on Jun 15, 2008
Needing a part# for the door gasket on my lg wm2016cw front load washer. we bought it used and the seller didn't have the manual.
I have this washer, and the owner's manual. There are no part numbers listed anywhere. I need to replace my door gasket as well :(
Feb 07, 2011 | LG WM-2277HW Front Load Washer
The frabric sofener and bleach will not empty in model lg wm-2277hw
This happened to mine about 2 years ago. I replaced the cold water valves/solenoids and this corrected my problem. The cold water inlet has 3 separate valves. One of the hoses that leads from it dispenses water into the softner and bleach sections "cups". I hope this helps, (I just got through replacing it "again" yesterday and one of the pumps that removes the dirty water out the drain)
Sep 06, 2010 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer. I am trying to remove the big nut
the best way is to have some one hold the drum from the front and turn the nut. it can also be done sometimes by turning the drum in the opposite direction and then pop it with the wrench. not the best way but it works.or you can hold the stator assy with one hand and tap your wrench with a hammer.i hope thia was helpful,would like to here how things worked out.
Jan 22, 2010 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
TROMM LG WM-2277HW
You may have a broken door latch switch that doesn't tell the computer that the door is actually closed.  Before you actually replace the latch switch, make sure the wire connectors are securely attached to the latch assembly.
Sep 14, 2008 | LG WM-2277HW Front Load Washer
BOTTOM DRAIN HOSE LEAK
http://136.166.4.200/contents/Laundry/WM2277.htm
Try that website and download the service manual..
Hope that helps...
Aug 07, 2008 | LG WM-2277HW Front Load Washer
Problems with LG WM-2277HW Front Load Washer
It is a rare problem but I've seen it happen.  The only way to resolve this issue immediately is to remove the top of the washer to gain access to the dispenser.  The dispenser can be disassembled by unsnapping the top section where the hoses are connected.  Once the top section is lifted, you can safely pull the drawer out.  Not sure what happened but more than likely the water dispenser has warped downward causing it to jam the drawer.  Recommend replacing the dispenser to resolve this problem.
Jul 23, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer not working with ce showing
CE is an error stating that you have a problem with you board or possibly the stator on your unit. Either way your going to need service. You can ohm out your stator to see if it is the problem.
Check the back harness, maybe it has come loose, remove the back panel and it is the blue connector.
Sgt 48
Jun 07, 2008 | LG WM-2277HW Front Load Washer
if you send the fax # or your add i can mail it to you
Feb 04, 2007 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
464 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
