Question about Cycling
I want more speed for raider 150...is it safe to remove the compression release?will it provide more speed?tnx...
3 Suggested Answers
cardiffspoke
  • 101 Answers
SOURCE: suzuki raider 150 after market carburetor bad idling
you can turn the idle speed up with the brassy looking screw on the side of the carb. It attaches to the part the throttle cable turns.
Posted on Aug 16, 2012
gregg201
  • 51988 Answers
SOURCE: Mga bosing ask ko lang po kung ano problem ng suzuki raider 150 ko bigla nalang namamatay in high speed or low speed marami na po kasi ako napalitan sensor carburator spark plug
Hi, Norlan the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Water or dirt in the fuel system, carburetor or filter.
11. Restricted, blocked or kinked fuel line.
12. Fuel tank empty.
13. The gas cap is not venting properly or fuel tank venting system blocked.
14. A failed fuel pump, pressure regulator and or fuel injectors.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
Loss Of Power Troubleshooting Bogging Down BuggyDepot com 150cc...
http://www.singaporebikes.com/forums/archive/index.php/t-119629-p-3.html
Why is the engine bogging under acceleration Suzuki FA50 Moped
Suzuki Raider 150 FU150SC Owner Manual
http://mototh.com/files/suzuki/Raider-150R/Suzuki-Raider-150R-parts.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Posted on Apr 25, 2016
HELLO PO. TANONG KO LANG SANA PAANO GGAWIN SA RAIDER 150 REBORN NA AYAW MAGSTART ANO PO KAYA ANG PROBLEMA, MAY GAS NAMAN PO. NAGLOLOKO PO KAPAG IISTART NA AYAW NA PO MAGTULOY
https://translate.google.com
HELLO. I NEED TO HELP HERE TO REMOVE RAIDER 150 REBORN WHICH WILL BE PURCHASE WHAT IS PO SO PROBLEM, THERE IS GAS PO. COUNTRY WHEN IISART THAT WILL BE PLAYING
Jul 22, 2018 | NA Computers & Internet
Suzuki R150 Raider wiring diagram
Hi, JM for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Suzuki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Suzuki R150 Raider wiring diagram Google Search
Suzuki Motorcycle Wiring Diagrams
Suzuki Raider 150 Service Manuals
https://www.partsfish.com/page/oem-parts-for-suzuki
Jul 05, 2018 | Suzuki Motorcycles
Apr 25, 2016 | Suzuki Motorcycles
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
Noise inside engine side of my suzuki raider 150 r when i put pressure on clutch
It may need adjustment
PDF]Suzuki Raider R150 owners manual (eng).pdf - Moto TH
mototh.com/.../suzuki/Raider-150R/Suzuki-Raider-R150-Owners-Manual...Your Suzuki dealer has experienced technicians that are trained to provide your ... The frame and engine serial numbers are used ..... PART ADJUSTMENT AND.
Apr 28, 2015 | Suzuki Motorcycles
Hard starting engine of suzuki raider 150
nag spin ang motor engine ko pero ayaw mg start, maitim ang spark plug then amoy gas yung lumalabas sa muffler
Sep 24, 2012 | 2010 Suzuki Sixteen 150
Suzuki raider 150 after market carburetor bad idling
Aug 16, 2012 | Cars & Trucks
Will the 66 tooth rear pulley from the Raider fit my V Star 950 ? i want to lower my revs at cruizing speed. i can get a 150 tooth belt that should work with the Raider pulley
Hi, Kenthedrumme after careful deliberation 4 out 5 Yamaha Gods give this one a thumbs up, but just to be on the safe side you should give your local dealer's parts/service department a call to confirm.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.yamahastarstryker.com/archive/index.php/t-1797.html
PULLEYS AND BELTS THAT WORK WITH RAIDER
2009 2010 2011 2012 2013 2014 2015 2016 Yamaha Star 950 Tourer XVS95... $10
OEM parts for Yamaha
YAMAHA XVS950A Owner Manual
Sep 12, 2010 | 2010 Yamaha V Star 950
Trying to remove starter from 1987 Dodge Raider.
If you use an extension on your ratchet that's longer than the starter, and a universal socket, you should be able to get it.
Jun 17, 2009 | 1989 Dodge Raider
Cycling Logo
143 people viewed this question
Top Cycling Experts
Marvin
Marvin
rigger094
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
