Question about HP OfficeJet V40 All-In-One InkJet Printer
How to undo a cartridge jam? - HP OfficeJet V40 All-In-One InkJet Printer
  • 1,218 Answers
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Posted on Nov 04, 2010
How do I undo a paper jam
of course as cafefully as possible
Jan 28, 2015 | Kodak ESP 7 All-in-One Printer
LOCATION OF PRINTER SENSOR
Jams
Clearing jams
CAUTION Do not use sharp objects, such as tweezers or needle nose pliers, to remove jams.
Damage caused by sharp objects will not be covered by the warranty.
CAUTION Always pull jammed media in the direction it would travel through the paper path.
Do not pull jammed media against the direction of travel through the paper path to avoid damage
to the printer.
To prevent damage to the printer when clearing jams, including jams in the output bin, always open the
print-cartridge door and remove the print cartridge. Keep the door open and the cartridge out until the
jam has been cleared. Opening the print-cartridge door and removing the print cartridge relieves tension
on the printer rollers, which prevents damage to the printer and makes the removal of jammed pages
easier.
Occasionally, media becomes jammed during a print job. You are notified of a media jam by an error
from the software and the printer control panel lights. See Control-panel lights (HP LaserJet 1010 series
printers) on page 102 or Control-panel lights (HP LaserJet 1020 printer) on page 106.
The following are some of the causes of media jams:
The input trays are loaded improperly or are too full. See Loading media on page 25.
NOTE When you add new media, always remove all of the media from the input tray and
straighten the stack of new media. This helps prevent multiple sheets of media from feeding
through the printer at one time, reducing media jams.
The media does not meet HP specifications. See Media specifications on page 21.
Typical media jam locations
Print cartridge area: See Removing a jammed page on page 43.
Input tray area: If the page is still sticking out of the input tray, gently try to remove it from the input
tray without tearing the page. If you feel resistance, see Removing a jammed page on page 43.
Output path: If the page is sticking out of the output bin, see Removing a jammed page
NOTE There might be loose toner in the printer after a media jam. This toner clears up after
a few sheets are printed.
Use the procedures in this section to remove a jam.
CAUTION Media jams might result in loose toner on the page. If you get any toner on your
clothes, wash them in cold water. Hot water will permanently set the toner into the fabric.
Partshere Troubleshooting
CAUTION To prevent damage to the printer when clearing jams, including jams in the output
bin, always open the print cartridge door and remove the print cartridge.
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print
cartridge with a sheet of paper.
NOTE The following illustrations show the HP LaserJet 1020 printer. The same procedure is
used to remove a jam in the HP LaserJet 1010 series printers.
Open the print cartridge door, and remove the print cartridge.
Grasp the middle edge of the side of the media that is most visible, and carefully pull it free from
the printer.
jams. Damage caused by sharp objects will not be covered by the warranty.
Do not forcefully pull jammed media against the direction of travel through the paper path to
avoid damage to the printer.
When you have removed the jammed media, replace the print cartridge, and close the print cartridge
door.
After clearing a media jam, you might need to turn the printer off then on again.
NOTE When you add new media, remove all of the media from the input tray and straighten
Sep 25, 2011 | HP LaserJet 1020 Printer
Jam cartrige Area
Clear jams from the print-cartridge area
1. Open the print-cartridge door, and remove the print cartridge.
Figure 18: removing print cartridge
2. With both hands, grasp the side of the media that is most visible (this includes the middle), and carefully pull it free from the product.
Figure 19: removing jammed media
3. Replace the print cartridge and close the print-cartridge door.
Figure 20: reinstalling the print cartridge
For any other Jam types Visit the following link : HP Lasterjet M1522
Regards,
Shrey
May 30, 2011 | HP LaserJet M1522nf Multifunction Printer...
I recently aquired a HP psc 2410 all in one printer. Upon start up I got an error msg that the cartridges are jammed, unjam and press ok. Well there doesnt appear to be a jam. The cartridges slide back and...
There is little or no value in older printers.
However the unit has gots its positioning confused.
Try switching off and on printer several time, opening lid for cartridge change to see if it can synch itself again.
Please dont forget to vote if you liked my answer
thanks
Feb 07, 2011 | HP PSC 2410 All-In-One InkJet Printer
Are the threads on the nut for the crankshaft pulley left or right handed?
Hi they are normal nuts so will undo anticlockwise, but to undo this nut/bolt your going to need to lock the flywheel you can do this by either removing the starter motor and jamming a big screw driver in the teeth of the fly wheel so that it lock on the casing of the gearbox or you can undo an inspection panel on the gearbox to give you access to the fly wheel and then jam it that way other than doing this you would need air tools to undo this nut without jamming the fly wheel
May 22, 2010 | 2000 Nissan Frontier
How do I undo paper jam
you can't undo paper jam , but you can fix it, please open the printer and remove the paper, this depends on the Epson model
Mar 30, 2010 | Epson Office Equipment & Supplies
Cartridge is jammed
I have a canon pixma 780. It was working fine then I had a paper jam and message "Cartridge jammed" I removed paper with no difficulty-piece was not torn.Now it will not print at all Paper feeds through but no printing in any colour
Mar 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My HP photosmart c5280 keeps saying there is a carriage jam. what is this?
Lift the printer cover. undo the 2 screws (torx head). remove the right hand end of the printer casing.
You will see a blavck plastic moulding with a couple of gears (it controls the cartridge cleaning). This is the cause of your jam - it is out of sync. Turn the machine on and watch what happens with this moulding you will see what I mean by out of sync and it can just be gently pushed back into alignment. Once it is ok turn the unit off and then on again and your jam should be cleared. Put it back together again and print away.
Jan 07, 2009 | HP Photosmart C5280 Printer
Print cartridge stuck
I had the same issue ,I had to unscrew the top and then undo the screws that attach the green board with the processing unit on it ,then you will be able to see the cartridge .Now push the cartridge down with screwdriver at the end furthest away from the opening ,or lift the printing mechanism and slide the cartridge out .this will fix the problem of the stuck cartridge ,but I had the same problem with the next cartridge so will probably end up throwing the thing out .
Nov 11, 2007 | Kodak EASYSHARE Printer Dock Thermal Photo
HP OfficeJet V40 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
