Question about Bernina Artista 180
Struggling setup Hi there, I bought my wife the 1080 and the simple things like threading we cannot do. The unit also does not seem to move while threading, perhaps even is pushing the material too hard. Can you please assist she is extremely eager to get started
  • Anonymous Jul 14, 2008
    how do you thread a bernina...and how to you fill the bobbin...please let me know asap
Just a thought but try making the presser foot not push to tight on the material. most unit's have some sort of a knob to change this.
I HOPE THIS IS HELPFULL :)
Posted on Jun 18, 2008
Hi, my wife has just bought a juki hzl-f600 machine and almost immediately the top thread cannot pick up the bobbin and the thread gets caught when sewing.
If this is a brand new machine, it should be covered under warranty. You can take it back to the vendor and ask them to replace it since it is a defective unit.
Apr 01, 2017 | Juki Sewing Machines
I need to replace lower looper field assembly as the clip at the end is broken. I'm struggling to source the part, i think the part no is x7777-001 but it seems to be discontinued. i bought the machine...
I have the same problem with my brother 1034d the small bolt in the thread guide has come off and I can't thread lower looped with out the thread breaking, I have looked everywhere and cannot find a replacement part, have you had any success ?
Oct 05, 2013 | Brother 1034D Mechanical Sewing Machine
Bernina 1080 cuts thread in reverse
Hi, is the top tension too tight? as this is often the problem. Try loosening it
Hope this helps,
Sally
Jan 17, 2013 | Bernina Sewing Machines
I inherited my mother's Tiptronic 2040, and needed to sew a simple seam. I admit to not having much experience. I have re-threaded it several times,; re-worked the bobbin but the top thread keeps getting...
Deep breath. Ohmmmmm.... ok now.
Few things you need to know.
1. Try to remember TTN when you run into problems like this it stands for Thread, Tension, Needle. Contrary to popular belief, there is no such thing as universal thread and needles. You'll need to determine what kind of thread and needle is best for your application.
2. When things gets bunched up under the fabric it Usually means that the tension for the top thread is too loose. However, a bad, bend or just plain wrong needle will cause these problems too.
3. Always grasp the threads (both top and bottom) and pull gently backwards when starting a seam. Some old school seamstresses and seamsters say to make sure your needle is at its upper most position (just before it starts to move down) before you begin sewing.
4. since you've had a couple instances with this issue... you might have to clean the bobbin race area. I'm a bit reluctant to tell you about this but remove the bobbin and look carefully for other stray threads, dust bunny's etc.
I hope this helps some. ;o)
S
Mar 12, 2011 | PfaFF Tiptronic 2040
Just bought the machine like two hours ago, as I sew, there is too much loose thread on the bottom. Not sewing corectly.
Your problem is in your threading, not the bobbin. Watch your dvd that came with your machine. If, there wasn't one, call Singer at 1-800-4singer and ask for one. Also, do not use cheap thread, there is too much lint. You can also try this test, to make sure that you are threaded right, with presser foot up, pull on your top thread, it should move smoothly, now lower the presser foot, it should barely move. You can download a manual at www.singerco.com , under the customer support tab and enlarge the diagrams for threading . While you are there, save a copy on your computer, that way you will always have your manual handy. I have this same machine and I use metal bobbins SA156 and it seems to sew smoother. (They can be bought on ebay for $8.99 for 20 of them with free shipping. Good luck.
Oct 30, 2010 | Singer 3116 Simple
My wife is frustrated with her sewing machine and just threw the material down in disgust...there seems to be a problem with the tension or something like that. She cant get a simple stitch without the...
I have a simple and I have better luck when I use a SA156 metal bobbin. Another thing, has she watched the cd that came with the machine? This machine is a little touchy as far as threading goes, I have been sewing 50+ years. Usually, it is in the top threading that causes the problem. If, she has a question, she should call Singer at 1-800-4singer and they will walk her through all of the threading and other troubleshooting strategies. Good luck. Hope this helps you.
Oct 04, 2010 | Singer 3116 Simple
Hi, I am unable to do a overlock stitch , elna l1
Check with sewusa for a threading guide and manual.
Look inside the font door of the machine to see if there is a threading guide.
Feb 28, 2010 | Sewing Machines
Thread tension for regular seam sewing
oil the shaft for the presser bar and keep moving it up and down(it may take a while) until it moves freely. Always use Sewing machine oil Not 3N1 oil.
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on top and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension). If you have loose thread on top your top tension is probably too tight and your bobbin thread too loose
Mar 23, 2009 | Sewing Machines
Singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Mar 15, 2009 | Singer 3116 Simple
Euro pro sewing machine fix
IF EVERYTHING LOOKS GOOD, ONE THING THAT WORKS FOR ME IS TO TAKE A HAIRDRYER AND MAKE SURE THAT THERE ARE NOT ANY THREADS/DUST BUNNIES HIDING AND NOT LETTING EVERYTHING RUN SMOOTHLY.
Aug 25, 2008 | Euro-Pro Shark 80 - 7133
Sewing Machines Logo
64 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
