Question about Panasonic Televison & Video
Panasonic DVD combo model #DMR-ES36V DVD player not working - no signal comes up on television We tried to record and pressed a few buttons We have read instruction book over and over but it is hard to understand how do we correct this so our DVD will work. Thank you. Arlene Hall
2 Suggested Answers
hawk12online
  • 16 Answers
SOURCE: NEED UNLOCK CODE FOR PANASONIC DVD RECORDER DMR-ES36V
I beleive FixYa Terms of Service state that you cannot give out Unlock codes for any type of device, hardware or software.
Posted on Dec 30, 2008
No read on my 2008 panasonic dvd recorder DMR-EZ485V
Insert a lens cleaning disc into it and let it play. If this do not help you, the optical pickup unit to your playder is faulty, and should be replaced.
Apr 30, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
How to copy VHS tape to DVD on the Panasonic DMR-ES36V?
You need a macrovision filter to put between the VHS player and the DVD recorder. They're getting difficult to find, but can still be had.
I found this one on eBay. Search around, you'll surely find others.
http://cgi.ebay.com/SIMA-GODVD-VIDEO-COPIER-ENHANCER-WIT-CABLES-WORKS-GREAT-/120744542961?pt=LH_DefaultDomain_0&hash=item1c1cef82f1
Jul 04, 2011 | Televison & Video
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
Remote broke how can i record vcr/dvd player . wnat to record on my vcr?
I assume this combo unit has basic front panel buttons (behind the right-hand door - where the copy button is) - there should be a drive select (VHS or DVD) button stop play record. I strongly advise if you really need a remote for this model, particularly when it comes to menu/setup options, that you search various online and similar stores for one.
The cost will depend where you go and who you deal with - and if the remote is available (you can always ask Panasonic about a remote for a DMR-EZ48V even though your model may be a DMR-EZ47V - they both use the same remote (N20AYB000136 or equivalent number); they can probably tell you how to order one through them, the price, etc.
A universal remote may work, but with limited functions. If the combo unit works in general, you should not have too much trouble obtaining a replacement remote (just keep in mind the model above).
The remote may cost just over $100 but remember, this is only if you want full control of your combo unit.
Mar 13, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Jun 04, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
My dvd player remote wont work!
Hello, Lallenbadan
More than likely the code for the remote/dvd player was reset accidently and is now incorrect.Refer to page 19 of your manual for instructions on how to set the correct code for your remote.
You can download your manual here if needed..
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-ES35VS
Post back if that does not work, and I will try to help you.
Thank you for trying Fixya!
Mar 29, 2009 | Panasonic DMR-ES35VS
Dec 30, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr-es35v
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
Jul 29, 2008 | Panasonic DMR-ES35VS
Televison & Video Logo
154 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
