Question about Lincoln Electric K1297 AC/DC 225/125 Stick Welder
Coming out of the breaker box going to the welder plug what size wire should i use to run a lincoln 225 welder
  • 297 Answers
It depends on how far away you are going to be away from the breaker box, using a #2 wire should be fine for your welder.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 04, 2010
Lincoln Arc Welder AC 225 Wiring Diagram
won't have reverse polarity. There are only 3 wires, 2 power and one ground. It does not matter what power lead goes to what side.
Apr 19, 2012 | Lincoln Electric K1170 AC-225 Stick Welder
What size circuit breakers should I use for my 225 welder?
Look on the specifications plate...there will be an input voltage and/or current/wattage rating. If you need to convert watts to amperage then you would use the following formula:
p=e x i or watts divided by volts will give you the current(amps). I think that unit is 240vac(mine is) and I use a 40A 240vac breaker and have no problems(thats 9600 watts)..you will want to choose a breaker as close to the max rating as possible...don't go too high or the breaker won't trip if something goes wrong
Dec 16, 2010 | Lincoln Electric K1170 AC-225 Stick Welder
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln mig welder 180, 230 volt 20 Amp Input. BUT! Manual says use ''Super Lag 40 amp Double Breaker, Plug on Welder Is Nema 6-50 ( 50 Amp ) Wleder cord is 12awg. What wire should be used to wire it up in...
Inspector is correct! In wall or conduit wiring awg will always be greater than "open air" wiring. IE: the size of wire coming from your pole ... it's smaller than from your service riser into your meter. Code allows the cord to heat up... open air will cool it down.
Dec 13, 2009 | Lincoln Welding Tools
Welder doesnt turn on...
Have you connected the feed from your breaker box to ADJACENT lugs on a dual pole breaker? By code you must use a ganged breaker.
You should use a voltmeter to verify the plug is getting power on teh desired pins.
Sep 25, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln Electric K1297 AC/DC 225/125 Stick Welder Logo
379 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
