Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
MDB3100 Soap Dispenser Problem
By MtrBao on Jun 13, 2008
You advised to change water inlet valve, which I did. It works, but soap is still left in the cups even after a heavy cycle. Only used 1 Tbsp in each side, water seems hot and pressure good. Any ideas?
thanks
Comments:
Jun 17, 2008
- Thanks for this, it looks like very good advice and I will certainly give it a shot this weekend. Then will give proper follow up, including rating. Thanks for such a detailed response.
Jun 23, 2008
- Your help was great in replacing the water inlet valve, but other issues surfaced. Decided to just replace it instead of messing with it further. Fam was getting on me to get it done, and didn't want to pay a guy to fix a machine nearing the end of its service life. Will definitely be back on this site, as the help from you has been outstanding.
Jun 24, 2008
- Thanks again, I saw that the water level after the 10-sec delay after main fill was just touching the heating element. It didn't lose level, it just didn't fill quite high enough, so at that point I figured it could've been a float and/or a float switch problem. But I just got sick of messing with it basically. Kind of a cop out on my part, as I'm sure if I had more time to deal with it, your advice would've been just what was needed to get the job done. But like I said the washer had been down for about a month, and the natives were getting too restless.
Best Solution
posted on Jun 14, 2008
Very Helpful)
Illeagle
Rank: Guru
Rating: 88%, 489 votes
In the main wash, once it fills completely, stop the cycle, ccount to 10 then open the door and observe the water level. It should be filled to over the heat element and covering the pump cover. If you observe that then it is ok there. If the water level starts falling then you have a siphon issue. Your drain hose must then be adjusted to go across the top of the dishwasher and then form and form a dip or a loop so that you have a "trap" in the line and then attach it to your drain connection. Elevating the hose and forming a trap should eliminate the water drainage. Also, if the water level is correct, you should be able to listen to the wash arms rotating with a rhythmic, whoosh... whoosh, sound. If you observe this then it has to wash the soap out. If the water level is normal and you don't hear the whooshing, then you will have a possible filter or pump issue, which will require disassembly and inspection.The filter can be removed and cleaned under running water, using an old toothbrush,or similar brush to clean the holes. Also, you will want to inspect the upper and lower wash arms for obstructions or lime build up. Follow the link below for disassembly procedures and parts.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Post me back if you need any more assistance.
Dave E. (Illeagle)
Comments:
Jun 22, 2008
- Hello,
Just checking back to see if you neede any further assistance.
Dave E. (Illeagle)
Jun 24, 2008
- Thank you for your very generous rating! I am disheartened to hear that you had other problems that led you to replace the unit, but sometimes that happens. I always strive to put forth my best advice, so if I can be of service to you in the future, just ask me.
Thanks again,
Dave E. (Illeagle)
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
dishwasher not spraying everything eles ok. 5 yrs old
Answer
Westinghouse 904 water starts overflowing after prewash and at wash it does not stop the water i had... (More)
Answer
My Bosch dishwasher is filling and not heating, it drains fine starts filling but never completes a... (More)
Answer
An electrical panel breaker switch was replaced after the microwave and dishwasher both lost power.... (More)
Describe your Dishwashers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in Colton, CA
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
