Question about LG Over-the-Range Microwave
We have a over-the-range LG Microwave Model #LMVM2055ST purchased in 2006. It was working fine until today when I tried to heat something, it wouldn't start. The light works inside when you open the door. The message said hit Start or Power Level, but it didn't do anything no matter what buttons we pressed. WE pulled the plug and then plugged it back in, and then it said "Set time of day".....but again none of the buttons worked. The fan and the downlights do not work either. Can you give us any idea what is wrong?
  • 3,037 Answers
Most likely the touch panel is bad. You can try ordering a new one from repairclinic.com by searching with your model number. If you find that replacing it doesn't help, return the panel within 30 days and you are only out the shipping costs. With what you describe, it should be the panel itself. Let me know what you find out.
Benjamin
Posted on Nov 04, 2010
Water damage to microwave
There is a small sensor in the micro wave that controls the heat. You probably got water on the connections and shorted it out.
May 01, 2013 | GE Microwave Ovens
On stove bulbs what is the wattage I need to replace the two bulb's. Everytime I purchase bulbs they don't last long. LG microwave, model # lmvm2055st Thanks, Dave
There should be a sticker in the back that quotes this. 40 Watt is the highest you may go but....buy the 130volt brands as this is a higher rating for 120volt and it will not burn out as quick. Make sure it is an appliance bulb. Most hardware stores like ACE have them. Big Walmarts do too but check the package.
Jan 03, 2011 | LG LMVM2055 Convection/Microwave Oven
LG LMVM2055ST Microwave. went completely dead, completely
I replaced outer door with key panel on my LG MICRO MODEL LMVM2055ST which solved my problem but when I went to put the handle back on it did not fit. The tophole in new panel for the handle is round and the old one is rectangle. LG says I have right part can not help me.A new handle comes rectangle shape. What now?
Mar 15, 2010 | LG LMVM1935 Convection/Microwave Oven
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
LG Microwave oven LMVM2055ST
Same issue here. LMVM1935 about 2 months past warranty keypad stopped working. Apparently they need to add something in the manual about not boiling water on the range over which the microwave is installed (gee who would have thought that there would be steam over the cooktop and we should seal the membrane?).
The silver traces on the keypad got corroded and no longer conduct. After complaining to Sears (NO HELP) and LG (EVEN MORE INEPT) and running on 30sec button for about 6 months, I found a replacement keypad $30 w/ shipping and didn't break anything taking the door apart, thanks to the parts list link above. Thanks Rickzilla!
Life's Good, Their Keypad SUCKS, or apparently we are the only people that boil water anymore.
Sep 05, 2008 | LG LMVM1935 Convection/Microwave Oven
Microwave stopping working
check the fuse on the microwave. if its busted, something shorted out in the oven that tripps off your breaker. it could be your inverter.
Feb 19, 2008 | Microwave Ovens
LG Over-the-Range Microwave Logo
421 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
