Question about Panasonic DX-2000 Plain Paper Laser Fax
Panafax DX2000(au)opt I have a panafax DX-2000 is appeared with a message DX 2000(au)opt and it's freeze up. I try to turn off and on ,press all the key.but it's still frozen.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Unplug it. Wait 30 seconds and plug it back in.
    If you are getting the same results, I would have a technician look at it.
    Sergeant:
  • 284 Answers
If its frozen try to do a shipment set, and maybe a firmware update .. try these and if they dont work might be a main board
Posted on Oct 15, 2008
    Genius:
  • 2,120 Answers
Bad main pc board.
Posted on Aug 28, 2008
HAVE YOU TRIED A DIFFERENT CARTRIDGE
IF NOT SC PWB
Posted on Jun 20, 2008
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
I needs audio driver for hp compaq dx 2000
go to this site http://hp.driversdown.com/hp-drivers-list/s_90_1.shtml
Apr 08, 2009 | HP Compaq dx2000 Microtower PC Desktop
How Do I reprint a previous fax from my panafax dx-2000
Sorry, once the fax has exited the machine it is gone.
Check the JOURNAL for the fax number and send a request to the sender to re-transmit.
Mar 16, 2009 | Lexmark Office Equipment & Supplies
UF-585 (AU) OPT is showing on the screen...can't send or rec faxe
Open the toner door
press
function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
set
wait for machine to reboot
Jan 29, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Panafax DX800
On the fax press function and the number 7.
Then there is a seperate monitor button that needs to be pressed 4 times.
Next press * and you will see in the display that you have entered into service mode.
press the down arrow until you get to #6 ram initialize and press SET.
arrow down until you see ALL JOB CLEAR and press * this will show ram initialize for a few seconds and then go away. Memory has now been cleared.
Aug 07, 2008 | Panasonic Panafax DX-800 Plain Paper Laser...
PROBLEM IS DX2000 (AU)OPT
You need to do a SHIPMENT SET, or main pcb is bad.
Aug 07, 2008 | Office Equipment & Supplies
Panafax dx-800
Press Function, then 7
Press 4, then Copy/Set
(it should ask for a fax parameter, the one for the key sound is 010)
Enter "010", then Copy/Set
Set the parameter to "1" for Off, then press Copy/Set
Press Stop to exit back to the default screen
Jul 23, 2008 | Panasonic Panafax DX-800 Plain Paper Laser...
Panafax DX 2000
the only way to clear the password is to do a shipment set.
Apr 02, 2008 | Panasonic DX-2000 Plain Paper Laser Fax
Panasonic Panafax DX-2000 Super G-3
try to do a lbp fuser reset and lbp error log clear and let me know if that helps
Dec 24, 2006 | Panasonic DX-2000 Plain Paper Laser Fax
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic DX-2000 Plain Paper Laser Fax Logo
135 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
