Question about Zhone (6218-I2-200) Router
Where can i log on to the router or change its password?
I used to have a speedtouch thompson router and when i wanted to configure it i went to www.speedtouch.lan so whats the alternative with zhone routers.
    Scholar:
  • 72 Answers
To access the router's configuration you need to type its IP address into a web browser. The default IP is 192.168.1.1 but if that doesn't work you can find it out with the following steps:
  1. Go to Start->Run
  2. Type "cmd" without the quotes into the box and press Enter
  3. type "ipconfig" without the quotes into the larger black box and press enter
  4. The number across from the "Default Gateway" is your router's IP address
I hope this helps!
Posted on Jul 09, 2008
Forgot pasword router
did you change the password ?
Click the "Wi-Fi" network icon located on the Window's taskbar.
Right-click the name of your network's "SSID" name and select "Properties" from the drop-down menu.
Click the "Security Tab." The network security key is now visible but unreadable.
Click the "Show Characters" check box and this will reveal your wireless password.
or
Log in to the router.
Routers typically have the IP address "192.168.0.1" or "192.168.1.1" for their configurations.
When connecting to the proper router IP address, a password box appears. The default login for Linksys routers is no username and "admin" for the password.
The default login for most other routers, including D-Link, Netgear and Belkin, is "admin" for the username and "password" for the password.
View or change the wireless password.
This is either a WEP key or a WPA/WPA2 password.
Some routers allow the direct viewing of the password, while others mask the password.
If the password is masked, the only option is to change the password to something else.
Connect to the wireless network with either the revealed or changed password.
Recover the System Password
Hold in the reset button on the router for 10 seconds and disconnect the power.
Continue to hold the reset button for 15 seconds while reconnecting the power.
Release the reset button and wait 60 seconds.
The router has now been reset to factory default settings.
Log in to the router as in the previous section.
Hope this helps
Sep 25, 2012 | Thomson Genuine Unbranded Tg585 V8...
Forgot password and want to change
reset the router by holding the reset button for 30 seconds.
the default login is
  • Username = admin
  • Password = password
    • For older devices, password = 1234
Apr 10, 2011 | NetGear WGR614 Wireless Router
How do i password protect ny speedtouch home network
Try this link:
http://www.thomsonbroadbandpartner.com/dsl-modems-gateways/products/index.php
Look up on top of page for Select a product>click the V>scroll down until you find your model. Speedtouch is now Thompson the model numbers are the same.
Oct 04, 2010 | Computers & Internet
How do i do port forwarding on a speedtouch router
Are you using a BT Thompson speed touch? And if you are the ISP may block the ports to prohibit customers hosting servers etc.
Jun 30, 2010 | Alcatel SpeedTouch Pro (3EC18804HC)...
Cant connect to internet with thompson speedtouch router what can i do. Ihave windows 7 the router was working but not now
ring your isp and inform them of the problem, they will give you a password and address to enter and this will sort it, i have had that problem before, just makesure that you write it all down so if it happens again you can rely on that info again
Apr 17, 2010 | Computers & Internet
Need username and pwd
To access the configuration: The default user is 'Administrator' and the password is blank.
Make sure you have your DSL username and password to log into you DSL service. If you don't have it your service provider can give it to you.
If that doesn't work find the reset button on the back. Do not use the front reset. Hold the reset buttion in until the power led flashes red. This should reset the unit back to factory. You will need probably need you DSL username and password to re-configure the router.
Mar 06, 2010 | Thomson RCA DCM245R Modem
When I connect my wireless router to my computer the speedtouch cannot be detected by my computer therefore I have no internet on my computer but I have wireless on both laptops which are directed through...
you probably have the router set to static ip so first you have to assign your pc with an ip range of the router , then log in the router set to dynamic ip and make sure you connect cables as per router manual. if it does not work then disable firewall , enable upnp devices . After configuration of wireless router you can enable firewall again. If you are using vpn with speedtouch then you should configure speedtouch to store username and password to connect to isp
Sep 11, 2009 | Computers & Internet
I have a thompson speedtouch 510 that works just fine but when i add my SPARKLan WRTR-141 it wont get connected neither by the computer or the laptop. i have 2 ethernet cables i added one end of the first...
Have you gone into the SPARKLan and configured it yet? It should be like this Speedtouch>SPARKLan>your computer in to the SPARKLan.
Turn on your new routers SSID so it can be "found" by the wireless devices. You should turn OFF the DHCP server in the Speedtouch and turn DHCP ON in the SPARKLan.
Hope this helps.
Jan 13, 2009 | Computers & Internet
Speed touch 576 - lost CD. Download online possible?
You can download the software for your router here: http://info.aol.co.uk/help/broadband/router_drivers_install.html
There is also a guide there for installing the software right underneath it!
When you run through the setup , it will actually help you setup all of the security , such as the WEP...so that should clear up that problem for you.
If it does not , you can also login to the router to change this information by doing this:
  1. Open up your web browser (Internet Explorer/Firefox)
  2. Enter the address 192.168.1.254 in the address bar
  3. You will be prompted for a username - "Administrator"; leave the password blank
  4. You will now be on the home screen of the router, click the link for "Configuration"
Both ways will enable you to change the routers encryption so that you know the password.....best of luck!
Sep 27, 2008 | Computers & Internet
Zhone (6218-I2-200) Router Logo
1,310 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
