Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
Image sensors yazz226, how difficult is it to replace this sensor? Should it be done by a professional? Thanks
  • Bowguy Jun 14, 2008
    Thanks. I'll do that.
    Master:
  • 497 Answers
It is better if u contact the customer care because any image sensor problem are treated "free" of charge...if you still have the warranty it would be helpful too...
Have a nice day!
tc
Posted on Jun 14, 2008
  • Yaz  S
    Yaz S Jun 14, 2008
    thanks for the vote Bowguy
I am getting a code cof32 code
Recommend you replace the developer in the image it. Be sure to clear counters first then run the required F8 procedure after re-installing the image unit, of course you ATDC sensor which is located below the image unit is bad, worse case the control broad is bad. If the developer was replaced was the person who replaced using a vacuum cleaner if so might have destroyed the sensor. NEVER use a Vacuum cleaner to remove the developer static electricity can destroy that sensor. Also since the image unit will be apart replace the drum and cleaning blade. Normal done that way. Again ensure counters are clear first as that is the only way the copier knows it has a new drum and developer. As the machine uses the counters to determine voltages for certain assemblies such as drum and developer unit. Clearing counters without replacing parts causes image problems and codes!!!
Try this site for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 13, 2015 | Konica Minolta Dialta Di3010 3010f 3510...
Minolta 450 di error code COF32
Have the developer replaced. if you have had the developer replaced and that person used a vacuum cleaner to remove the old developer then the static electricity from the vacuum cleaner destroyed the sensor underneath the image unit. Worse case the main board that sensor feeds is bad now. Go with replacing the developer again first. Then worry about the sensor or the main board. Was the counter reset when the developer was replaced, was the F8 process done after the developer was replaced.. If not then get new developer have the process done correctly, the machine works on what the counters have in them if you replace the developer and don't clear the counters the machine will assume the that old developer is in the machine and adjust the voltages to certain units accordingly when in fact new developer and for that matter the drum also works on that system. is installed causing image problems and codes.
Mar 10, 2013 | Minolta Office Equipment & Supplies
Canon g12 purple
If you have a purple image or an image problem, this is most often caused by a faulty imaging sensor. If you need to have that replaced or even have the camera serviced for that issue, we do not recommend taking it apart. When dealing with the optics, it should be done by a service professional. If you need to have that one serviced, you can have it done here: www.camerasandparts.com These guys just specialize in the Canon Powershots and nothing else, the work through them is superb. For that problem, it runs $89 through them for parts / labor and the servicing for the camera, plus they cover the return shipping which we like. The best part, they do outstanding work on the Powershots and they are actually reasonable price wise. They'd be the place for help with that one, best of luck with it.
Jun 25, 2012 | Canon G12 Digital Camera
My speedometer bounces when i hit 45 miles an hour, what do i need to do?
Hi.
Problem is usually the speed sender failing when speed gets too high. In some case the speed gauge itself is damaged. In Mercury the speed sender is located in the transmission. The part is difficult to test without professional equipment. Repair is done replacing the speed sender. If that does not fix the problem, work on the instrument panel speedo.
Here location of the speed sender:
May 12, 2011 | 1996 Mercury Tracer
The lcd picture image is ok but after you take a picture there are lines across the lcd and are there when developed
The image sensor has failed, not an uncommon fault. The only fix is to replace the sensor and it's a professional job only.
Replacement costs far more than your budget priced camera is worth, so unless it's under warranty recycle it and replace it, and remember to remove the memory card and batteries if reusable. If your camera is under warranty then Vivitar won't even attempt a repair: they'll just verify the fault and replace the camera with another one (same or equivalent model).
Mar 04, 2011 | Vivitar ViviCam 8300s Digital Camera
Taking a picture
The CCD image sensor has failed (a common problem on ALL makes and models of older digital cameras).
Your camera is around seven years old now so has far exceeded it's design life. Repairing it is not realistically feasible: it's a professional job and it's going to be difficult now to obtain a functional spare sensor as even the old unused spare ones will now be liable to age-related deterioration. It also means that even with a successful repair, there's no guarantee as to how long it will last.
You may hear about some Sony models which had a massive recall due to premature CCD failure: this was for the 5MP sensor which had a manufacturing defect leading to failure in under five years. Yours is the 3.2MP sensor and has certainly given it's money's worth, so there is no free recall repair option.
Sorry there's no fix for this, but at least you can rest assured that your son hasn't done anything to cause the fault. Your only fix is to recycle the camera and replace it completely.
Manufacturing processes have improved, but the fault remains common. Even expensive Nikon digital SLR's still only have a maximum two year warranty, so always bear that in mind when considering how much to spend on new cameras or on previously owned ones; no current digital model is designed for more than a five year maximum operating life, although plenty do last longer. Digital cameras offer many advantages over film, but a long lifespan is definitely not one of them.
Please take a moment to rate my answer.
Jul 23, 2010 | Sony Cyber-Shot DSC-P52 Digital Camera
Spot on images
Sorry, I read this as being for a Nikon N70 35mm SLR, but now see that it's a Canon EOS 350d.
In that case, you simply have a dirty image sensor. Either use a DIY sensor cleaning kit on the sensor (put the camera body into "sensor cleaning mode" to expose the sensor), or get a professional cleaning done. Professional is best for a one off, but as the problem will re-occur then there's no substitute for the experience you'll gain by doing it yourself. Until you get good at sensor cleaning, just clone out the artefacts using your preferred image editing software.
May 27, 2010 | Nikon N70 35mm SLR Camera
Insallation of oxygen sensor
Replacing an O2 sensor is not difficult to do but sometimes they are rusty and the threads on the exhaust pipe will come out with the sensor. Basically there is one wire and a proper O2 sensor socket should be used. A proffesional shop may do the job in 10 minutes but they will charge according to the industry standard (time wise).
May 20, 2009 | 2007 Dodge Charger SRT8 Sedan
Ricoh color aficio 6513
The following is taken from the service manual I hope it helps Thanks J
SC457 Position error for
the image
transfer belt’s
cleaning unit
- Timing & Condition
• When the belt cleaning
section touches the
image transfer belt, but
the belt cleaning sensor
signal remains LOW.
section releases from the
remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning
shift clutch
• Defective drum
peripheral component
motor
• Defective I/O control
board
• Defective main control
board
1. Pull out and re-insert the image transfer
belt unit.
2. Clean the image transfer belt cleaning
H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-
012)
4. Replace the belt cleaning shift clutch.
(Output Check: SP5-804-036)
5. Replace the drum peripheral component
motor.
6. Replace the I/O control board.
7. Replace the main control board.
[Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O
control board
Jan 06, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
48 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
