Question about Maytag Washing Machines
My legacey washer is leaving lint on clothes - Maytag Washing Machines
  • 244 Answers
Of course you've probably already done this but if not, check the filter and clean it. Additionally, you might need to wash it to remove residue from dryer sheets and BE SURE TO DRY IT BEFORE PUTTING IT BACK IN THE DRYER. If the filter is clean and washed and you're still having lint, get a dryer brush and clean down in the area where the filter goes. Also go to the vent area outdoors and clean that with the dryer brush. That area can become clogged over time and prevent the dryer from effectively removing the lint. Furthermore, check the exhaust piping. If it is bent, gently move it a little to dislodge any lint that might have gotten stuck there over the years.
Posted on Nov 04, 2010
  • Carlton T DeVaughn Nov 04, 2010
    this is a washer not a dryer
Top load GE High Efficiency washer has been leaving excessive lint on dark clothing. How can I fix this problem?
Clean out filter also spin clothes in dryer the lint catcher in the dryer will catch the lint.
Nov 15, 2014 | Washing Machines
CLOTHES COMING OUT OF WASHER WITH DARK STAINS
Hi Lynn, this is AP.
I understand you are seeing stains and lint on your clothes once removed from your top load washer, model FWS833A. There could be several culprits causing this to happen. To confirm, are the stains not being removed during cycle or do you believe the washer is the cause of the stains? If you believe the stains are being caused from the washer it could possibly be undiluted liquid fabric softener poured directly on fabric. Something more serious could be a broken transmission causing oil to leak in the tub.
There are some basic troubleshooting tips for lint to check such as undissolved detergent can leave residue on clothing. Separate clothing items which shed lint from items which attract lint. Permanent press, synthetic, knit and corduroy items will pick up lint from towels, rugs and chenille bedspreads. Make sure to Use correct amount of detergent, water temperature and water level.
There are some simple troubleshooting tips listed above and in your owner's manual, if you find they do not resolve your concern I would recommend contacting a local authorized technician to inspect the washer.
Thanks,
Mar 30, 2014 | Frigidaire FWS833A Top Load Washer
Washer leaves white lint like spots all over dark clothes.
This happens to me as well but only when I overload my washer or when my washer needs to be ran thru its cleaning cycle.
Mar 10, 2014 | Whirlpool Cabrio Washing Machines
My Kenmore 22642 washer is leaving lint all over the clothes. If i run them through the dryer, that will remove the lint... but some of my clothes don't go through the dryer. I can't seem to determine if...
Wash clothes separately whites and light colors together. Darks with liquid detergent. No lint filter on the machine. I have found some powder detergents do not dissolve completely.
Dec 26, 2010 | Kenmore 22642 Top Load Washer
We have a Whirlpool top loading washing machine that leaves the clothes covered with lint after each load. Delicate clothes that have elastic bands are covered with pieces of lint on the bands that are...
Your service man is right, the lint is filtered through the filter plugs on the bottom of the tub, and backflushed out during the spin cycle. This does not do a great job of filtering out the lint that came out of the clothes. So why is there so much lint? Three reasons: 1. Clothes being beaten against the agitator, tub, each other. The Whirlpool washer has a pretty decent way of agitating the clothes without too much damage, as long as there is plenty of water for the clothes to move through. As long as you make sure your load size and water level are correct, this shouldn't cause a lot of lint. I always have a larger water level than the load size calls for. 2. Lower quality material in the clothes. We definitely see this a lot, especially in the cheaper towels, rugs, sweaters, ect. Some of these have such cheaply made fibers, that they put out a lot of lint. 3. Laundry soaps. Most soaps are very caustic detergents and eat the fibers right out of the linens. There are some brands of washers that still use a type of metal in them that this soap eats right up, so in a few years the machine is junk. All of the washer manufacturers went to plastic outer tubs, as the soap was literally eating holes in the outer tubs in 2 to 3 years on some brands. This is one of the reasons we have so much of the micro lint that is so fine, it goes right through your dryer lint filter and causes lint build up in the venting itself. Years ago, at our shop in Hawaii, we tested naturopathic soaps for 12 years before we settled on the Melaleuca brand for our laundry soaps. Ph neutral, cleans the clothes better than any brand we have tested before or since, does not leave the sludge in the outer tub that most brands do, does not leave a hard aggregate in the tubs like some other brands do, is cheap and does not cause the allergys, athsma, skin rashes, ect. that most of the caustic brands are doing. We have used it for over 10 years now and see very little lint in our Whirlpool washer. Look it up online, join it, and buy the soap directly from the company. It sounds like you have done everything else correctly to the washer, that you could have. I am impressed, most people could not have done what you did. Hope this helps. Good Luck, Appliance Specialists
Jan 22, 2010 | Washing Machines
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Lint On Clothes
seperate the ones that are leaving the lint
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Crosley CAWC529JQ1 top load washer LEAVES LINT ON CLOTHING
try washing on a shorter time as this washer may have too good of wash action and the lint is fabric coming off your clothing
add more soap powder and do not buy the cheapest soap as the soap is important in the washing cycle of your machine
towels that are not too soiled brobably need 6 minutes at most on wash
if this machine has a delicate wash cycle use that for tee shirts etc
water pressure is important in rinse cycles
do you have high pressure and water only trickles in check water inlets on back of machine where the hoses screw on
good luck
Nov 27, 2007 | Crosley CAWC529JQ Top Load Washer
Washer leaves too much lint on clothes
There are many things that cause lint. Some are easy to figure out, some aren't. Here are some of the most common things: 1. Separate clothes that are lint givers from lint takers (i.e., sweaters are lint givers and should not be washed with cotton which attracts lint). 2. Check clothes pockets for tissues or paper. 3. Don't overload the machine. 4. Use enough detergent to hold the lint in suspension. Read the recommended usage on the detergent bottle. 5. Use enough water to rinse the lint away. Washing large loads on a water saver mode is not a good idea. 6. Use fabric softener to reduce static attraction of lint. 7. Washing clothes on too long of a cycle, too often can cause premature wearing of the the fabrics. I hope some of this may help you. PS Adding a cup of plain white vinegar to the rinse cycle has also been known as a "cure" for controlling lint.
Apr 04, 2007 | Kenmore 22442 Top Load Washer
Washing Machines Logo
99 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
