Question about Xerox Office Equipment & Supplies
Fuser Assembly for Xerox Copier 5309 PN 126K3410
I want to replace the Fuser Assembly on my Xerox Copier 5309. Where can I purchase this component.
    President:
  • 2,072 Answers
Right here
https://www.partsdrop.com/store/
Use that link, ask for Britt, he will fix you up. Tell him Rick said Hi. Haven't talked with them for a while..
Posted on Jun 13, 2008
WHERE IS THE THERMAL FUSE IN A XEROX COPIER?
It is usually an internal fuse in the FUSER Assembly that limits or reports the fuser temperature to the control board..
May 24, 2014 | Xerox XC356 Copier
Error U4-1000 (Xerox CopyCentre C116 copier)
U4-1000 Indicates Fuser on time failure
Follow these steps:
1. Check for paper on the fuser.
Y remove paper N proceed to step 2
2. Check the installation of the fuser assembly, make sure it is securely installed.
Y reinstall fuser N proceed to step 3
3. Remove the fuser. Check the conductivity of the contact points of the thermostat, are the contact points connected
N replace the fuser
Apr 12, 2011 | Xerox CopyCentre C118 Copier
Xerox 5225 fault code 010-320???
If you have a Xerox WC5225 with Error Code 010-320, then you have a fuser problem. The fuser is the heated item which bonds the image, just before it exits the unit. The machine monitors the temperature sensors and heating elements on this part.
The fuser is sold as PN 126K24980. It is easy to replace yourself.
Nov 23, 2010 | Xerox DocuColor 3535 Copier
Fault code 010-327
This is a fuser error, so we'd start by replacing that. The fuser PN is 126K16480.
This particular error code may be a false error, in which case either the Power Unit 105E11370 or the MCU Board 960K09910 might be bad.
Whit
Item, Inc.
Oct 02, 2010 | Xerox CopyCentre C128 Copier
I have received an error code of 010-327 and I need to know what this is
Fuser thermal error. Check for paper wrapped around the rollers, but you will need to replace it.
PN 126K24980
Whit
Item, Inc.
Jun 25, 2010 | Xerox WorkCentre 52255230 Copier
Xerox Phaser 7700DN jam at fuser
Those rollers are necessary to feed paper from the fuser. Order PN 116-1759-00 which is the 15 inch long shaft w/ 4 rollers
Whit
Item, Inc.
Nov 10, 2009 | Xerox Phaser 7700DN Laser Printer
OUR XEROX COPY MACHINE MAKES A SQUEALING NOISE WHEN MAKING COPIES
On this model most squeeling noises come from the fuser assembly.
If it is that loud replace the fuser assembly.
Other known prolbems is with the fuser fan in the back.
To see if it is the fuser fan, take off the back cover.
When the machine makes a copy unplug the fan very momentary. See if the noise goes away.
If the noise is still there, then it is possible the fuser is causing the problem.
Make sure the correct fuser is installled on this machine model.
Oct 21, 2009 | Xerox CopyCentre C20 Black and White...
Xerox 416si print or copy are dirty
the problem is upper heat roller of the fusing unit are defective.try to ask xerox u.s.a if you can buy only the upper heat roller.
Apr 14, 2008 | Office Equipment & Supplies
Replace Fuser Gear Xerox XC1040 Copier
Call a tech!. You first remove fuser assy from machine. One green screw to loosen and then you figure the trick out to get it out. Then once its out remove cover 2 screws I believe. Remove the lamp gently, you can do this with out unscrewing anything. Then remove the little clip on end of heat roller, simple spread clip and replace gear. It takes a tech about 10 min.
Feb 13, 2008 | Office Equipment & Supplies
96 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
