Question about Samsung Vacuums
Samsung SC8571 VACUUM CLEANER
I am looking for parts for the SC8571 vacuum cleaner. Mainly the tubing including the handle and machine end.
Can anyone help - I am in Australia
  • 328 Answers
Either check your local region of EBAY for any vacuum cleaner repair specialists who may be able to sell you a replacement hose/parts OR enter your postcode in Australia for this Samsung customer service:
Dont forget to rate.
http://www.samsung.com/au/support/repairlocation/ServiceLocationsMain.do
Posted on Jun 13, 2008
  • Ryan S
    Ryan S May 27, 2015
    If you check the rating plate by the motor of the Samsung vac, it should have a model number.
Doesn't suck
Vacuum Cleaner Repair Help
How to Fix Vacuum Cleaner
How to Fix Vacuum That Lost Suction
If there's ample suction but the machine won't pick up material, check the hose for blockages. Disconnect the hose from the vacuum cleaner and inspect it for any cracks or holes. If any are found, use duct tape to repair them - it might not look great, but it does the job! Where there's a blockage in the vacuum cleaner, clean it out by pushing a long, thin object like a broom handle through the entire length of thre hose. You can then reconnect the hose and try the vacuum again. It's worth checking the hoses a few times every year for cracks or splits.
If everything else appears to be fine but the vacuum still won't pick up, take a look at the brushes. Turn the vacuum cleaner upside down and clean hair and other material from the brushes, especially at the sides.
How to Troubleshoot Vacuum Cleaner DoItYourself com
Jul 24, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
How can I lower the handle of my kenmore vacuum cleaner to the vacuuming position?
Left lower side is a handle/pedal wich you push with your feet!
May 02, 2014 | Kenmore Vacuums
Clogged Sebo automatic X-1 vacuum
Hi There,
So when this light is displaying, it's says "Bag Full or Clog" on the indicator. If you have changed the bag, and it's still showing this light, it means that you either have a clog in the vacuum, or your filters are dirty, which is reducing the suction and making the machine think that your bag is full. If your machine is actually cutting off, this indicates that your machine is definitely clogged, or something is stuck inside which is causing the motor to not get air flow, and cauing the machine to over heat. When it shuts off like this, it's a protection system that prevents any damage from happening to the motor when it can't breathe and starts to overheat.
My guess is that there is probably a clog in the machine somewhere, or the filters are dirty. Here's what you may do to diagnosis the machine, and try to isolate the clog to find out where it is in the vacuum.
Step 1. Remove the hose and wand assembly from the vacuum cleaner completely. You may do this by pressing the two tabs on the end of the hose that plugs into the vacuum cleaner:
With the hose and the wand removed from the vacuum, it should look like this:
Step 2. Now turn the vacuum cleaner on and check to see if the red light comes on while the hose and the wand have been removed. If the light comes on, then this indicates that your filter is dirty (or the PCB electric board is bad if the filter is clean) and needs to be replaced.
Step 2. Re-attach the hose and wand back on the vacuum, but just the end of the hose that goes into the vacuum cleaner, leave the wand out of the vacuum cleaner so it looks like this:
Turn the machine on now as if you were using the attachment hose to clean corners or above the floor and see if the red light comes on here. Also listen to the noise the motor makes and see if the noise changes when you put the hose back on the vacuum cleaner. If the red light appears, or if the motor makes a higher pitched noise now, then this indicates that you have a clog in your hose or wand. You may verify this by remove the hose again from the vacuum, and also removing the wand from the hose by pressing the hose release button on the wand and pulling the hose out of the wand. Look down both of the parts and see if you can see thru both sides. If you're not able to see light through the hose, or the wand, this indicates this is where the clog is. You may take a metal clothes hanger, and try removing the clog this way.
Step 3. If the red light did not display with the wand not inserted into the vacuum, put the wand back into the vacuum cleaner as if you were vacuuming the floors:
Turn the machine on, and see if the red light comes on in this position. If the light does come on, then this indicates that you have a clog in the bottom of the vacuum cleaner. To check and see the clog in the bottom of the machine, I find it easiest to remove the upper bag housing from the vacuum cleaner completely so you're just looking at the bottom power nozzle of the vacuum cleaner. There's a button at the bottom of the machine that is either a grey, or yellow color depending on what color your vacuum is. Simply press this button in, and lift upwards on the handle or the bag housing at the same time:
Step 4. After the bag housing has been removed, turn the lower part of the vacuum upside down so the brushes are facing upwards. There's a little orange flap on the bottom of the machine that is actually a clog port. Almost every time there is a clog in a Sebo, this is where I typically find the clog. Open up this orange colored trap door, and look to see if you can see any obstruction or clog underneath of here:
Step 5. You may rotate the neck of the power nozzle part towards you so that you may look inside to see if you see any obstructions inside:
Step 5. You may also remove the brushes from the vacuum and look behind the brushes at the suction port, or the area where the suction goes through the vacuum to see if you see anything obstructing the suction here.
These are really the only places that the Sebo can get clogged. If you checked all of these areas, and the red light is still displaying, this means that your PC Board that controls this indicator has gone bad, and needs to be replaced. If this is the case, please just reply to this repair using the comment field, and I'll be more then happy to help you through the replacement of replacing the PCB Board.
I hope this answer was helpful to you, and you were able to find the clog and fix the problem. If you found my repair helpful, please be sure to rate the repair by clicking the 4 thumbs up icons in the top right hand corner, or by leaving feedback for me. This is really what keeps repair professionals continue to post free repair solutions rather then just the paid questions. It's really appreciated when you take the time and do this if the repair was helpful.
Thank you so much,
Jan 29, 2013 | Sebo Automatic X1 Bagged Upright Vacuum
Looking for manual LG Roboking Vacuum Cleaner
you tube shows operation and parts on video
Oct 02, 2012 | Vacuums
Red light on then cuts out how do i unblock please? lost the manual.
Hi There,.
Aug 09, 2012 | Sebo X4 Bagged Upright Vacuum
I have a Dyson Animal vacuum. My wife removed the handle to use some of the attachments for cleaning. When placing the handle back to the vacuum, she attached the top part of the handle back to the...
Sorry to hear you're having difficulties with your DC07 Animal. From what you've described, it sounds as if the wand has been replaced on the cleaner without the hose being retracted. To remove the wand from the machine, hold the cleaner securely in place by placing one foot on the cleaner head, then pull the wand up forcefully whilst holding the purple quick-draw hose release (located above the on/off switch) down. Make sure you are not leaning over the top of the wand as you do this.
Once you've freed the wand from the cleaner, make sure you retract the wand before replacing it on the cleaner again. Hold down the hose release button on the hose cuff as you retract the wand inside the hose.
You might find it useful to refer to the user guide supplied with the cleaner - in case you don't have this to hand, you can download a copy here:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
If you have any further queries about using or maintaining your Dyson cleaner, please call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide the assistance you need. Alternatively, you can resolve many issues without picking up the phone by visiting www.dyson.com and clicking 'Support'.
Kind regards,
Jack
Dyson Online Customer Support
Aug 28, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
My vacuum cleaner start up fine, then quickly
Hi There,
This is a telltale sign that your vacuum cleaner is clogged. When the motor makes the higher pitched louder noise, your motor is not able to pull air through it, and has to strain harder because it's not able to breath.
Because you have already narrowed it down, that the noise only happens when you put the wand back into the vacuum, this means that you clog is definitely in the bottom section of the vacuum cleaner. Most clogs on upright vacuum cleaner occur right at the suction port behind the roller brushes on the bottom of the machine. Turn the vacuum upside down so that the brushes are facing upwards. Unscrew the bottom plate of the machine so that you may access the roller brush and belt. Look behind the brush roller for the opening of the vacuum where the suction port it. Look inside here and see if you can visibly see anything lodged inside. Sometimes just pushing a long screw driver into this hole can dislodge the obstruction.
If you aren't able to see anything in this port, and the screw driver doesn't dislodge it, look inside the small section of how that the wand connects into, and try pushing your screw driver down this hose to see if you can dislodge it from this part.
Sometimes a metal hanger can also effectively unclog hoses on vacuum cleaners, but just be careful that the hanger doesn't tear the lower hose section while you're pushing it through.
Also if you have another vacuum in the home, using the hose from the other vacuum and putting it inside the lower hose, or the suction port behind the brushes while you're pushing with the screw driver will also many times dislodge the obstruction easier.
Please let me know if this was able to unclog the vacuum cleaner, and I'd be more then happy to try and do some more advanced diagnosing with you for your vacuum cleaner.
If this was helpful to you, please help other Fixya users find this repair by rating helpful. This is greatly appreciated, and is what keeps Fixya repair experts continue giving free advice on the site.
Thanks so much,
Chris J.
GoVacuum.com
Apr 11, 2010 | Kenmore Progressive 35922 Bagged Upright...
PLASTIC HANDLE RELEASE BROKEN. WHERE DO I FIND A REPLACEMENT?
Greetings from GoVacuum.com,
We are a vacuum cleaner parts store, http://www.govacuum.com, and we carry parts for over 40 different brands of vacuum cleaners.
We almost certainly carry the handle release pedal for your vacuum cleaner. If you'd like to leave your vacuum cleaners brand, and model number (can be located on the back or the bottom of the vacuum cleaner on a sticker that will also contain the serial number), I would be more then happy to help you not only find the part you need, but also explain to you how to install the part.
Please feel free to click on "Clarification Request" here on Fixya, or send me an email to chris.jones@govacuum.com.
I look forward to helping you find the correct part for your vacuum cleaner, Please vote this repair as helpful by clicking on the 4 Thumbs Up Icons in the top right hand corner of this repair.
Thank you so much,
Chris Jones
GoVacuum.com
Mar 19, 2010 | Vacuums
Self propel unit broken
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner2_bing.gif by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum2_bing.gif cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
Feb 23, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Sebo Automatic X1 vacuum cleaner doesn't produce much suction.
If the motor really is working, the problem is most likely to be that there's a blockage somewhere, and on this excellent vacuum cleaner there aren't too many places to look. You've probably already looked in the inspection flap on the underside. If not, that's the first place to look. Next is to separate the bag compartment from the base of the machine (press and hold the button at bottom front of bag compartment and just pull the two sections apart - if this hasn't been done for some time, a gentle levering with something like the plastic handle of a dish brush can help). Then look down the rearmost vacuum tube to check that it's clear, also make sure the little sieve on the other tube is clear. That's all for the base section. Now open the bag compartment, remove the bag and check that tube all the way through the hose.
Another possibility is air leakage, and it does happen on older machines that the plastic tube onto which the attachments fit becomes so worn that it no longer seals properly in the hole in the base (where it lives for normal floor vacuuming).  You could also have split in the flexible hose, of course.
If none of this reveals a problem, the motor probably isn't as healthy as you think it is.
I hope this helps. Any questions, just post again and I'll see what more I can do.  I value your feedback, so please rate this response.
May 04, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Vacuums Logo
239 people viewed this question
Top Samsung Vacuums Experts
Ryan S
Ryan S
woodzowl307
Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
