My touchpad will move around the screen but it will no longer stop by tapping it. The left and right buttons work but the tapping of the pad has ceased to work. Any help there?
This just happened on my HP2730P. I always used the click on the
touchpad, plus used the right click button at the bottom. Yesterday it
just decided to stop working and went haywier...it started doing the
selecting and dragging while I was moving the mouse around and my left
click stopped working. Obviously my enable tap click was already on cuz
I used it all the time.
My solution was disabling the buttons under the "buttons" tab. Then
my mousepad tap started working again, I regained function in the
scrollbar on the mousepad again, and if I need to right click I can use
the point stick buttons right above the pad.
OR
Does it start working when you reboot? If so, try changing the "Touchpad Sensitivity" option :)
is there a touch pad lock button, that locks the pad? if there isn't then there is most likely excess debris or dust or something under there that needs to be blown out with airisol can. If both of those solutions don't work then i would check to make sure the driver is installed for the touch pad. Good Luck. and i hope it works out.
Here is what I did to get the touchpad to start working again. My laptop is Gateway and a couple years old, running Windows Vista.
1. Start>Control Panel
2. Double-click on Mouse icon (or button, depending on how you're systems set up).
3. When a the Mouse Properties window pops up, choose the Device Settings tab.
4. Click on the Settings... button.
5. A new window pops up and on the right side there is a list of options - choose Tapping.
6. Once clicked, there is a check box that allows you to Enable Tapping.
7. Click OK to close out your windows and the tapping option should be enabled on your touchpad.
My Vaio touchpad started behaving strange. I could move the curser, but no response on left or right click or double tap. Also found that in any search field or user name fields, the computer would just type endless 9's. My wireless mouse could operate the left and right click buttons, but not move the curser. A suggestion to get the mousepad operating again was to touch any key on the keyboard. This allowed it to function again. Final solution was to remove the battery, then hold down the start key for about a minute, reinsert the battery and start it up. It seems to have resolved the problem. I have a 3 month only laptop with Windows 7 already installed. Hope this helps.
Goto 'Control Panel - Mouse - Device Settings, Highlight the device in the list and then click settings. It Might just be that it needs re-configuring. Devices like this tend to loose there configuration due to being used so much and of course the ammount of pressure put on them. There is alot you can reset here. The touch pad does alot more than you think, We just dont bother to look at the settings because we are too busy looking at the screen,and rightly so. Im not saying this will rectify the problem but its worth a try.
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Go to the 'start' button and then hit the 'control panel' option, then click 'mouse' then go to 'Device Settings' and then to the 'settings'. When you get to this screen it shows a list on lthe left hand side choose the 'tapping' option and then ok.
