Question about Kenmore 57029 Side by Side Refrigerator
Ice forming on the panel on the back wall and temps 40-44 on the top shelf but freezing on the bottom shelf
  • 3,037 Answers
Improper air flow is your problem, Defrost it first. Then make sure that the fan inside is running, if it isn't, replace it. Repairclinic.com will have what you need, just search with your model number. Let me know if you need anything else.
Benjamin
Posted on Nov 04, 2010
Samsung refrigerator is freezing up on back panel of refrigerator . Will defrosting the whole unit do any good? The unit is 2 years old
well yes and no , defrosting it will temporally make it work , but main problem is there isn't proper air flow over evaporator coils id clean them with soap and water while defrosting out unit , if low airflow is allowed to continue then refrigerant gas will build to high press and escape and render unit a total replacement
Sep 29, 2016 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Danby DAR1102W
make sure coils are back like they should be
Jun 24, 2012 | Danby Designer DAR1102W Refrigerator
My refrigerator has temperature a problem. The top shelf is about 60 degrees and the bottom shelf has ice on back wall and partially freezes food.
open the door,push in the two switches on the top,the lights should go out and the fan on top should be blowing,you can remove the light cover to see the fan,if the fan isn't working cold air will stay at the bottom and the top will be warm.if there's an ice block just on the left side back wall around 2 feet up from the crisper draws then you have a freeon leak in the coil and it has to be changed but it sounds like theair isn't ciculating,bad fan motor.
Mar 05, 2011 | Sub-Zero 690 Side by Side Refrigerator
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice and water on the bottom shelf
the blower motor of your fridge which is located at the back panel of your fridge is not running
Mar 06, 2009 | Refrigerators
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Bottom drawer wall is covered s ice/ top shelf not freezing
Sounds like a defrost system problem. Could be related to defrost timer, heaters or defrost thermostat. Have it serviced.
Jun 09, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore 57029 Side by Side Refrigerator Logo
186 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Bailey's...
Bailey's...
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
