Question about Kenmore 71812 / 71814 / 71819 Bottom Freezer Refrigerator
Kenore bottom freezer
Where do I find and access the drip tray in this unit. The model number inside the fridge says: 596 72914200
  • 254 Answers
The drain pan is located at the bottom in front of the compressor you should be able too see it when you take the toe kick off. If you go to www3.sears.com you can look at a picture of the unit just put in your model number make sure you put the number in as 596.72914200 that period is important you will need too look in the compressor section of the parts breakdown.
Posted on Jun 13, 2008
  • I just noticed bottom mount, you should have an access panel on the back of the unit.
How do I get to the drip tray on a Samsung American fridge freezer? Awful cheesy smell so think it's that...
  1. Consult the owner's manual for the location of the drip tray.
  2. Gently attempt to remove the piece under the doors to see if the drip tray is located there.
  3. Some Samsung refrigerator drip trays are accessible only from the rear.
  4. Reply with the model number for more assistance.
Dec 16, 2015 | Samsung Refrigerators
Where can I access the defrost drain hole in my Kenmore model 253.74879404 Refrigerator? Disassembling the freezer did not work.
I've used used a compressor for that drain hole at the back of the fridge. A hanger wire will work too. I've never tried it but maybe a can of compressed air might work also.
The water drain line is plugged and that little catch tray is overflowing. That's why you're ending up with water under your bins inside the fridge. The problem is not in the freezer or else you'd have a skating rink on the floor of the freezer.
I don't recognize the photos exactly but they're all the same principle. Take everything out of the fridge , including the racks. It's far easier than o find the screws and disassemble the drain "catchall".
Good luck.
Dec 18, 2014 | Kenmore Refrigerators
My Westinghouse fridge freezer, model WSE6100SF, was affected by a power cut lasting 3 days. It now smells, but not inside. Is there a drip tray under the fridge that collects the water?
yes there is but most are not removeable.... remove the cover in the rear of the fridge, the pan is located around the fan motor that's underneath the fridge... I would try pinesol, bleach or odoban to kill the smell..... good luck
Oct 09, 2014 | Westinghouse Refrigerators
Where can i find a drip pan for a S1621 silhouette dometic rv fridge
use make and model number with brand and look in manual for it there should be a parts replacement list with phone number
May 26, 2014 | Dometic RGE400 Top Freezer Refrigerator
How do I remove the plastic drip tray from behind my Wesitnghouse Aurora Fridge Freezer.
we had a really bad smell coming from the back of our westinghouse aurora. and yes found it to be emanating from drip tray at the back. To remove this we had to undo 4 clips at the base of black motor thingy, that the plastic drip box sits on. Then we were able to lift whole thing a bit ,(10mm up and 50mm out, approx) so we could tilt everything forward and sweeze and wiggle tray out. then cleaned with bleach. also we unblocked hole inside fridge that allows water to drip into drip tray at back.
Jun 01, 2011 | Westinghouse Refrigerators
Water leaking daily from area below freezer, inside the fridge cavity. need to place containers to collect water and empty frequently.
sounds like outlet pipe is blocked at back of fridge unit, this is accessible from inside of fridge at the back and towards the bottom, remove any debris and feed through a relatively stiff piece of wire to unblock pipe, the idea of this is to take away excess water and feed it into a drip tray on top of the warm compressor where it then evaporates, however this can and does get blocked with food debris from time to time,.
Oct 26, 2010 | Whirlpool Refrigerators
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Kenmore 71812 / 71814 / 71819 Bottom Freezer Refrigerator Logo
182 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
