Question about LG Dryers
When starting the gas dryer, the ignitor glows for a few seconds then goes off without the gas turning on. previous to this I would have to reset the switch on the high limit temperature sensor. I replace the sensor with a new one but it didn't help.
  • Alan Clark Nov 13, 2010
    I did as was suggested and changed the ignitor - this didn't make a change. The new ignitor glows like the previous one for a number of seconds and goings off without any gas being turned on.
    What next?
  • LG Master
  • 43,501 Answers
If the high limit was tripping then the thermostat was also bad....that is why it was getting too hot and tripping the high limit. When replacing one the other should always be replaced also...
So, in your case I would replace the thermostat and then also maybe replace the ignitor...they can glow and still be bad sometimes....
checkout this gas no heat tip....
heatman101
Posted on Nov 04, 2010
Turns on but. Will not heat upb
The areas that come to mind is the ignitor and/or sensor has gone bad The most unlikely is the gas valve but it is a possibility. I check for a thermal fuse on your model It does not come with one. That eliminated another cause.
Attached is a picture for reference.
When the dryer is turned on, the ignitor ( #74) will start to glow and in a few seconds to a bright orange color. The sensor ( #79) which is located on the outside of the flame tube, detects the heat intensity from the ignitor. Once the ignitor has reached its limit when operating correctly, the sensor will give a signal for the gas valve to open and release gas through the burner where the ignitor will light the gas. This process repeats several times when drying a load.
Defective ignitors will either have no glow or the will glow a little bit.
Hope this helps you out.
Always you caution when working on appliances.
Nov 16, 2010 | Frigidaire GLGQ642A Gas Dryer
BURNER TURNS ON ONLY FOR A FEW SECONDS THEN SHUTS OFF,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 01, 2010 | Maytag MDG8000AWW Gas Dryer
Electrolux frididaire serial XD40615481 02/04 electric heater comes on then goes out after a few seconds, fan stays on and drum keeps turning.
heatman101
Aug 31, 2010 | Electrolux EIGD55H Dryer
Whirlpool gas dryer Model #WGD5530SQ0 not heating properly
If your dryer heats when you first turn it on and after a few minutes it does'nt. check the ignitor to see if it is glowing. It should glow bright then you will hear a click and the burner will light. If the ignitor glows bright but you hear a click but no flame and if you watch this for several minutes and this process continues of glow then glow goes out no flame, then you have a bad burner coil. There are 2 black solenoids sitting on top of gas valve. One of them is shorting out after it warms up. Replace both solenoids. You can usually get them as a kit from parts store.
Feb 04, 2010 | Dryers
Not heating up Gas Dryer
Modern gas dryers do not have a pilot light. They have an electronic ignitor (glow or spark). A glow ignitor turns on several seconds before the gas turns on and should get orange hot. A spark ignitor should make a clicking or buzzing noise.
Most likely the ignitor is bad but you can check it fairly easily to make certain. The best instructions I have found are at
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/ignitor.php
If it is the ignitor it can be replaced with a few hand tools. Remove the bad ignitor. Write down the make, model, and serial # of your dryer. Call your local appliance parts store to see if they have one it stock before driving over there.
Dec 22, 2009 | Whirlpool Dryers
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 11, 2009 | Dryers
Stops heatinng
Hi, first thing to check is the venting. If the vent is plugged, it will cause the heat to short cycle.
If later in the cycle, the ignitor glows but will not ignite the gas, you will need to change the coils on top the gas valve. This is a common problem.
Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
No heat on whirlpool LGR4632EQ2 gas dryer
Well there are two main sources for this to happen # 1 The igniter can go bad if you can view the burner area turn unit on and watch for glowing ignitor,< takes a few seconds > if ignitor comes on and goes off without lighting burners then #2 flame sensor,< located on burner rail it attaches with one wire>, remove the one screw holding it on rail and remove,< clean it by scraping with sharp knife or something with an edge to it until it appears to be fresh metalic look. replace and try again and if this does not work then gas valve is probably source of failure.
Apr 23, 2009 | Dryers
Kenmore Elite Dyer Model # 11071082000
Hi. thanks for the question. the problem you have is with the coils ,on the gas valve. 2 little coils . replace them. thanks the appliance doc
Sep 30, 2008 | Kenmore 72802 Gas Dryer
Dryers Logo
53 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Craig Butler
Craig Butler
Are you a LG Dryer Expert? Answer questions, earn points and help others
