Question about Car Audio & Video
Installation of navigation/DVD unit in 2003 Chevy 2500
I just need to know where to attach the speed pulse lead and the reverse gear lead on a pioneer avic-d3x DVD/Nav headunit
  • GhostDog Jun 13, 2008
    No one can just tell me where to attach two wires huh? One is a speed pulse generator, the other is a reverse gear indicator. I have the owners manual for the AVIC-D3X, I need to know where the two leads attach inside the 2003 Chevy 2500.
  • 790 Answers
Hello sir ,
Read in some website which says
"The orange or orange white wire is part of the wiring specific to the Miata. It feeds the wire on the AVIC-D3 labeled "Ill", which I assume is "Illumination"."
Will it help u ???
Posted on Jun 13, 2008
    Genius:
  • 3,422 Answers
I'll letr you know if there is a user manual available
  • Priya darshan Jun 13, 2008
    Please CLICK HERE to view the manual it will help you fix the problem.
    All manuals are available in PDF Format and require Adobe Acrobat Reader. Click here to get the free Adobe Reader.
    Goodluck..
Chevrolet diagrams
Mary, 2003 Chevrolet Silverado 2500HD suspension and steering diagrams. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2003 Chevrolet Silverado 2500 Parts GM Parts Department Buy genuine GM...
2003 Chevrolet Silverado 2500 HD Parts GM Parts Online GM Parts Direct
Chevrolet Silverado 2500 HD Ball Joints eBay
How To Install Replace Inner Tie Rod Chevy Silverado GMC Sierra 99 06...
Aug 02, 2014 | 2003 Chevrolet Silverado 2500HD
I have a pioneer avh-p2300dvd in my car and i hooked up the parking break input to +12 volts because i want to be able to watch dvd's while driving(for my son in passenger seat) now my screen is stuck...
The parking brake (light green) connection needs to be connected to a (-) ground (black) wire, not a +12V wire. While it won't damage the unit to put +12V power to that wire, it does need to see a (-) chassis ground to view video while in motion. If changing this wire to ground still doesn't offer the solution, your Pioneer may require wiring of a relay as is necessary on several newer Pioneer navigation units.
Some Pioneer radios will still not allow video to be viewed even if the parking brake wire is grounded. For these units, I recommend using a standard 12V automotive relay (Bosch type). I would recommend consulting a professional installer if you are unsure about wiring this relay. Otherwise, if you are comfortable/knowledgeable, the instructions for wiring the relay are as follows:
85 - chassis ground86 - Blue/white stripe (remote turn-on lead from Pioneer)87 - chassis ground30 - Light green (parking brake lead of Pioneer)
The wiring of the relay will cause the parking brake lead to see the ground wire at the same time that the Pioneer actually powers up. This delay can be necessary for viewing video. An optional timing device can be wired in to do the same function such as PAC electronics' PTR-7.
The message that you are receiving for "screen image may appear reversed" is typically only visible when a reverse camera is used. For this, the Pioneer has a separate purple/white stripe wire for +12V reverse input.
I hope that this information was helpful.- Elliot
Nov 09, 2011 | Car Audio & Video
Pink wire whats it for, it on a pioneer avic-d2
The brake sensor wire (Lt Green) can be simulated with a toggle switch to ground.
Pink (CAR SPEED SIGNAL INPUT)
The mobile navigation system is connected here to detect the distance
the vehicle travels. Always connect the vehicle’s speed detection
circuit or the ND-PG1 speed pulse generator, sold separately. Failure
to make this connection will increase errors in the location display.
Orange/white
To lighting switch terminal
Light green
Used to detect the ON/OFF status of the parking brake. This lead
must be connected to the power supply side of the parking brake
switch. If this connection is made incorrectly or omitted, certain
functions of your navigation system will be unusable.
Violet/white
(REVERSEGEAR SIGNAL INPUT)
This is connected so that the navigation system can
detect whether the vehicle is moving forwards or
backwards. Connect the violet/white lead to the
lead whose voltage changes when the shift lever is
put in reverse. Unless connected, the sensor may
not detect your vehicle traveling forward/backward
properly, and thus the position of your vehicle
detected by the sensor may be misaligned from the
actual position.
Note: When you use the ND-PG1 speed pulse
generator (sold separately), please make sure
to connect this lead.
When you use a rear view camera, please make
sure to connect this lead. Otherwise you cannot
switch to rear view camera picture.
Further detail can be found here:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130AVICD2.PDF
Feb 23, 2010 | Pioneer AVIC-D2 DVD Nav/6.5"...
Speed sensor
The VSS or speed sense wire is used for navigation systems. The VSS wire sends a series of pulses (from 800 to just over 1,000 per mile) only when the vehicle is in motion. If the VSS wire is not hooked up, the navigation system will not realize that the car is moving at all, and will be unable to track position. If you need a wire color and location I can provide one for your vehicle. Hope this helps.
Mar 02, 2009 | Pioneer AVIC-D2 DVD Nav/6.5"...
Lincoln Navigator Dvd player will not read the Dvds
try cleaning the unit with a disc cleaner.and make sure all dvds are clean
Sep 10, 2008 | 2003 Lincoln Navigator
The navigation is off track or something
there should be a vss wire hooked up that helps the unit know where it is.. go to the connection check screen and make sure the speed sense is pulseing
Feb 22, 2008 | Pioneer AVIC-D1 Car Video Player
Pioneer Avic D2
I suggest u to take it for a general service, this includes lubricating and cleaning and alignment.
Hoping a rating from you...!!!
Thankyou
Feb 15, 2008 | Pioneer AVIC-D2 DVD Nav/6.5"...
Pioneer Navigation System
You will need a gps antenna, 30 pins data cable and an antenna extension to do basic installation set. For more precise set up you will also need reverse and speed signal sensor wires(pink and purple).
Nov 19, 2007 | Pioneer AVIC-N2 Car DVD Player
Car Audio & Video Logo
105 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
