Question about Whirlpool GBD307PDS Electric Double Oven
The thermal fuse on the oven needs replaced but I do not know where to find the part? Can you let me know where this fuse can be purchased?
  • 3,037 Answers
Here is a direct link to your part with the model number you supplied. Let me know if you need anything else.
http://www.repairclinic.com/Fuse-Or-Thermal-Fuse-Parts?s=t-GBD307PDS-%3d%3dc44
Benjamin
Posted on Nov 04, 2010
Kitchenaid Superbra double wall oven still not heating. Replaced thermal fuse of top oven; lower is OK. Also replaced the 2nd thermal fuse near the control panel on the top of the unit. Any ideas?
Get me a complete model # number for this oven We then can give you step by step what to check .Knowing how to use a meter Is a big help with any electrical issues . Getting Us the model will tell us what is used to control your appliance, The big and first thing to check is the power do you have it all were it needs to be most ovens run on two legs of 110/120 volt. in combo Make 220 volt It all needs to be there or you will not get proper heat
.https://www.youtube.com/watch?v=NOdYp8CFjdU&feature=share
Feb 02, 2017 | KitchenAid Ovens
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
If the thermal fuse is out on oven will the microwave still heat
If the Thermal Fuse is out, the oven will not get hot. you will need to purchase the fuse and replace it for it to work again. You will need to pull the oven out becuase the fuse is on the backside of the oven.
Jun 02, 2014 | Whirlpool GBD307PDS Electric Double Oven
Where is the thermal fuse located and how do I replace it on Whirlpool double oven GBD307PRS03? Thanks
The thermal fuse is located on the back of the upper oven to get to it to replace it the oven would need to be removed from the cabinet and the back panel removed ( not fun but what must be done) here is a image of what the thermal fuse looks like.
GENE
Oct 15, 2011 | Whirlpool GBD307PDS Electric Double Oven
Convection upper oven not heating. lower oven working fine. blower on upper oven working fine and pre heat shows when oven us turned on but upper oven does not heat.
I Have worked on quite a few of these in the last few weeks, i have found that about 50% of these problems are caused by the control board and the other 50% caused by the thermal fuse, you can check the fuse by removing the unit from the wall and checking for continuity at the thermal fuse. If the fuse is in fact ok then it is the board that is not sending the correct amount of power to the elements. So the Power Control Board is what will need to be replaced, you can purchase both of these parts at, http://www.reliableparts.com/ by using your model number.
Please rate my solution if it was helpful to you.
If you need more in depth information or pictures on how to remove and take this machine apart, feel free to ask.
Thanks, Repairman45
Dec 15, 2010 | Whirlpool GBD307PRS Stainless Steel...
Where is the thermal fuse located on an electric whirlpool in cabinet oven?
hello,
Instruction below.
  • Unplug your oven. Insert the size 15 Security Torx bit into your multi-bit screwdriver and remove the screws from the back panel. Take off the back panel.
  • 2 Locate the fuse. It should be near where the electrical cord comes into the oven. The fuse is a small white bar with metal caps on either end. Carefully remove the fuse. Avoid touching the transformer or other parts inside the oven.
  • 3 Purchase a new fuse. Most whirlpool ovens use an 18 amp ceramic fuse. Consult your owner's manual to find out what kind of fuse is used, or take the old fuse into the store to find the exact match.
  • 4 Replace the fuse. Put the cover back on and see if your oven works. If it does, replace the screws. If it does not, try a different fuse. If the oven still does not turn on, you may have to have it replaced of professionally repaired.
  • thanks,
    Oct 09, 2010 | Whirlpool RBS305PD Electric Single Oven
    After doing a self clean on a whirlpool oven model rbs245pd06 it will no longer heat on bake or broil.
    Unfortunately you have found out the hard way about the self cleaning feature... they cause many problems...
    Here is a tip that I wrote about that and it includes some things you can try to get you oven to unlock...
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Mar 30, 2010 | Ovens
    Whirlpool oven stopped working after self cleaning
    If the display still works but neither the Bake or the Broil elements wont heat up, it's likely that the Thermal Cutoff has opened and has not reset itself. This is a common problem after self Cleaning.
    The fix is to replace the Thermal cutoff which requres you to pull the oven and remove the back panel to get at the thermal cutoff.
    What happens is that in Self Clean, both Broil and bake elements are used and the oven gets so hot that the middle skin (between the oven liner and the back panel, where the thermal cutoff is mounted gets so hot the thermal cutoff operates. It should reset itself but sometimes doesn't and then you have to replace it.
    Nov 17, 2009 | Whirlpool RBS305PD Electric Single Oven
    I have a Kitchenaid oven model KEBC107KSSO. After using the auto clean, broiler and oven does not heat. Control panel works fine.
    The thermal fuse on the back of the oven is out. Usually happens if the oven is installed incorrectly or the blower is too small to cool the back of the oven down while in self-clean mode.
    I'd call KitchenAid (whirlpool) and ask if it needs the blower kit to fix it. Have your model&serial numbers handy.
    In case it does not need the blower kit, the thermal fuse part number is 9759242, and it can be purchased here (use coupon "New10" for 10% off). Read my other post for the instruction how to get to the thermostat.
    Oct 14, 2009 | Ovens
    Whirlpool rbd275pdb double wall oven died during self clean
    The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
    Mar 22, 2008 | Whirlpool GBD307PDS Electric Double Oven
    Whirlpool GBD307PDS Electric Double Oven Logo
    354 people viewed this question
    Top Whirlpool Ovens Experts
    ashburton
    Sal De
    Oloyede Monsuru
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
