Question about Kitchen Appliances - Others
WWM200PC Waffle Maker will turn on but does not heat up
Waffle maker does not heat up after it is turned on. We received this as a Christmas gift and have only used this maybe 10 - 12 times. What is the warranty on this product? Is there a reset button to apply? to reset the power Bought mine from Sams Club after seeing how great my sister's worked (and terrible the one we got from Target worked don't remember brand). Used it 4 or 5 times and it quit in the middle of cooking a waffle. I bought it in April 2007 so it is out of warranty. Took it apart and tested the thermal fuse which is blown. Will check with Waring Customer Service to see what they will do. As listed here a replacement part is less than $10 from Mouser.com.
  • 4 more comments
  • derfthemule Jun 14, 2008
    I took it apart and it is the thermal fuse that is mentioned under the WWM200PC thread. I called Waring Customer service and they said they would replace it. It appears to me to be a well known problem with this product.
  • Anonymous Dec 27, 2008
    recieved for christmas and when plugged and upon turning the timer knob : I hear a switch but unit does not heat up. ?  brand new never used.
  • dani-nelson Feb 14, 2009
    plugged in my waffle iron this morning and as it was heating up it just quit....the lights went off and everything...I have tried other outlets and nothing seems to work...the red power light wont even come on...frustrating...it has always made great waffles!
  • Anonymous Feb 22, 2009
    My Cuisinart waffle maker is a WAF RC. Less than one year old. Hadn't used it for 5 months. Plugged it in, it made a clicking sound when I turned the dial, like it was turning on, but no lights and no heat. Unfortunatly for me I don't have the receipt, it was a gift. Came from Canadian tire.
    Eva
  • Anonymous Mar 14, 2009
    same problemo
  • eltano767 May 13, 2009
    it does not heat up the upper part, could be this the same problem??
    Please Help!
    Problem Solver:
  • 8 Answers
Call customer service for repair. If they will not repair you can get a replacement fuse.
Posted on Jun 14, 2008
Testimonial: "Done, they replaced it in June 2009."
Check to ensure that all electrical connections are secure enough. Also, check the heating element. This should be done when the appliance is off (well duh, of course)
On my second use the ready light cover melted. Is it safe to use the waffle maker? Can this product be replaced?
I don't know much about waffle makers but indicator bulbs and their housing should never ever melt like that!! The product is not safe to use in this condition. I would suggest the heat from the waffle elements has somehow escaped into the waffle inards and melted other parts as well. You are entitled to a new replacement if it is only weeks old.
Jan 19, 2014 | Refrigerators
I received the Professional Belgian Waffle maker as a gift and have only used it twice. During the second use, about the third waffle, the heating element stopped working. What would cause this? I was...
I think this was caused by the premature failure of a Chinese thermal fuse; they are poorly made and while the principle is sound (opens if necessary to prevent fire), the components are really poor and most appliances that use a heating element fail without cause due to the lousy quality of those parts. Because of the high levels of heat where these are mounted, they are most often spot-welded in series with the element and cannot be soldered in repair. Try contacting the manufacturer, I'm pretty sure they know of the problem.
May 28, 2011 | VillaWare 2010 Waffle Maker
Waffles sticking to waring pro waffle maker no matter how much spray I apply. Help! thank you
I have had a bad experience with some corn oil spray. The oil (and corn syrup) built up into a crusty and sticky layer. I had to use oven cleaner to strip it back down to the non-stick surface. Now I just use soybean oil with a natural boar's hair pastry brush. (Synthetic will melt!) I heat the waffle maker at the last moment possible. Heat turns oil into varnish. I oil the surface just before the first cup of batter. I like to scrub oil with the brush into all the dry looking areas. If your batter has 1 Tbs (soybean) oil per waffle, that may be all you need for the entire batch. Turn off the heat promptly. I don't wash the oil out of the non-stick surface unless it builds up.
Mar 09, 2010 | Waring WMK300 Professional Belgian Waffle...
Waffle maker won't heat
There is a thermal fuse inside the bottom half of the unit, enclosed in a white insulating sleeve. A replacement can be found on Amazon.com at the following URL:
http://www.amazon.com/Thermodisc-Degrees-Celsius-Thermal-Fuse/dp/B000T9VEV6/ref=wl_it_dp_o?ie=UTF8&coliid=I2M3QCVRS1C1IV&colid=2LRN9SBBQ2MW7
Aug 24, 2009 | Waring WMK300 Professional Belgian Waffle...
Broken shaft
I made a template of the shaft, cut out a sturdy piece of tin to straddle the break, and then screwed that piece in at both ends after securely fitting the break together. A lot of work, but the waffle maker works great!
Dec 13, 2008 | Waring WWM200PC Waffle Maker
Waring Wafflemaker power light comes on but won't heat up
My just over 1-year old WWM200SA did the same thing while I was cooking with it (used it about 5 times). I found a solution under the WWM200PC thread that the thermal fuse blew early. I tested mine and that's what happened. It is a cheap part, but I called Waring Customer service (800-269-6640) instead and they said to send it in for replacement.
Apr 21, 2008 | Waring WMK300 Professional Belgian Waffle...
Heating element
I personnally just went through this.
If it is less than one year old, and you have the receipt, go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
My replacement had a silver body virsus the original black body. The shop told me they have yet had a customer repeat of this problem.
Feb 25, 2008 | Waring WMK300 Professional Belgian Waffle...
I fixed one of these for a friend - the problem was an open thermal fuse. This fuse is located in the fixed grill; it is clamped to the grill and is covered by a white plastic sleeve.
The replacement part should be a 240°C/464°F 10 - 15 Amp thermal fuse. NTE sells a part NTE8242 which works available from Mouser.com for $1.41 plus shipping.
May 25, 2007 | Waring WWM200PC Waffle Maker
Kitchen Appliances - Others Logo
501 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
