Question about Grex 23 Gauge 1 3/8 Inch Length Headless Pinner
The driver in my p635 will not retract after shooting
  • 297 Answers
Driver is either bent/burred or you have a pin double fed. Or does it make a hissing noise after you fire it?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 04, 2010
  • scottm1000 Nov 05, 2010
    i took the gun apart and the driver seems ok. the gun does make a hissing noise from the exhaust port that is quieter than it should be.
Grex p635 nailer just stopped working.....leaks air around trigger when pulled.... any suggestions?
You have an "O" ring seal leaking is my guess, take it apart and replace all the seals, any Auto parts store that is full service (not Autozone) will have an assortment of "O" rings so you can match them up. Use Silicone grease when installing the seals.
Jul 22, 2016 | Grex 23 Gauge Model P635 1-3/8" Headless...
Driver on my Grex P635 does not seem to be returning to the ready position
An Oring needs to be replaced... if the driver stays forward its usually in the trigger assembly
Nov 27, 2012 | Grex Headless Pinner P635 Nailer
FR350 won't shoot nails
Normally I would say you aren't using enough air pressure because somewhere around 80psi (every tool is different) will not be enough to fully retract the driver. At 110 you are fine so that is not the case. I doubt it is broken because a broken driver will still retract unless it broke near the piston. My guess is it needs the o-rings replaced but you can pull the top head and pull the driver out first to make sure. Parts and breakdowns can be found here as DeWalt owns Porter Cable.
PC FR350 diagram
Aug 19, 2012 | Porter Cable Air Tools & Compressors
How do I get nails to stop jamming?
make sure nails are not being put in backwards, your driver may be worn or broken
May 02, 2012 | Grex Headless Pinner P635 Nailer
Grex p635 leaking air when I hook up pinner it doesn't pin triggrr just leaks air
Sounds like the recoil is jammed. Take it apart & clean it up. Look for damaged seals.
Apr 01, 2012 | Grex Headless Pinner P635 Nailer
I have a ns100a porter cable narrow crown stapler. The driver will not retract, so it will not shoot staples. what can be the problem and how can I fix it? Thanks Pam
Usually when the driver is slightly bent, it will not retract. Easy to check. Remove the head and pull out the cylinder and driver together. Adjust the driver or replace as needed.
Jun 04, 2011 | Porter Cable Cable 18 Ga 1" Narrow Crown...
Driver pin on model FN250A not retracting far enough to drive next nail. Will shoot 2 or 3 nails and miss 6 or so.
I had the same problem with an electric stapler from Craftsman after years of disuse. The solenoid that powers the hammer that is no retracting may require lubing if this is possible.
If not, then if the product is within warranty, you might be able to get a replacement.
Jul 04, 2010 | Porter Cable Air Tools & Compressors
Driver blade won't retract to shoot the next nail
Sounds like you have something caught in the guide causing it to jam a lil.
These guns are allmost disposable and have a short life span.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Mar 31, 2010 | Porter Cable 2 - 1/2" 15 - Gauge Angle...
My hitachi framing nailer, the driver shoots a
There is a spring that is broken or the joint just needs some lubricant that can help take care of this issue
Apr 23, 2009 | Air Tools & Compressors
A4tech P635 installer/driver
search there site here A4 tech they should have it .
riz.
Apr 26, 2008 | A4tech PK5
Grex 23 Gauge 1 3/8 Inch Length Headless Pinner Logo
133 people viewed this question
Top Grex Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Grex Measuring Tool and Sensor Expert? Answer questions, earn points and help others
