Washing Machines Logo
Posted on Nov 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washer is not spinning the clothes on the rinse cycle, the clothes are wet at the end of the cycle. I tried again and still not spinning. I amell what I believe is a belt buned up. Is the spin cycle controled by a belt? how do I access the machine to change the belt?
Anonymous
Level 3:
  • Master 618 Answers
  • Posted on Nov 04, 2010
Anonymous
Master
Level 3:
Answers
618
Questions
Helped
128726
Points
1840
Make and model?????
2answers
My Lg too load washer sprays water during spin cycle
It is normal for a washer to spin and spray fresh water over the clothes during rinse period. I don’t know why it would leave clothes wet. Look at your options. See if you can turn off rinse n spin to just spin.
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
The wash cycle is not working. It doesn't agitate. Then the water drains and starts the rinse cycle. Then the spin. The spin cycle doesn't get all of the water out of the washing machine. Laundry...
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Clothes are not completely rinsed (they're soaking wet) at very end of spin cycle.
Try to fill minimum water level in your machine with out adding detergent or clothes and complete cycle and see if it is any watter inside. Could be a water pump.
6helpful
After the spin cycle runs the clothes are still soaking wet
I had that problem at one time with my old washer and what it ended up being was the Washer Dog Agitators were broken and causing the it to slip and not spin correctly. I would try checking the Dog Agitators.
Here's A picture of a typical top-load washer breakdown to show you where they are located --->Here<---
I hope this helps. If that is the problem I bought mine at Sears for about $8, normally in stock item.
moz-screenshot-2.jpgLet me know if there is anything else I can do.
1helpful
Machine won't rinse or spin properly..also stinks!
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
3helpful
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Front loead washer will not spin/rinse,
First, make sure that you do not overload the machine.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Top Washing Machines Experts
john h
