Posted on Nov 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the serial number of the printer canon mp258 printed? i lost the printer case..
Josh Whitehead
Level 3:
Genius:
  • Master 1,148 Answers
  • Posted on Nov 04, 2010
Josh Whitehead
Master
Level 3:
Genius:
Answers
1148
Questions
Helped
247350
Points
3024
Should be on the back of printer
2answers
7helpful
2answers
Reset canon pixma mp258
Reset Canon MP258 error 5B00 or P07
Indications
When the printer is turned on will show an error MP258 P07 in LCD panels and monitor screen will pop up an error 5B00.
Resetter Canon MP258
1. The printer must be in SERVICE MODE, the way
2. MP258 printer is turned off and plugged the power cord.
3. Press the STOP / RESET and hold, then press and hold the POWER button.
4. The power button is pressed, release the button STOP / RESET, then press the STOP / RESET two times, then release both buttons simultaneously.
5. MP258 printer will process (rather long), then the LCD Panel will show the number zero (0)
6. The computer will detect NEW DEVICE, Ignore it .....
7. This situation indicates the printer is on and ready to reset SERVICE MODE.
8. Download ServiceTool_V1074 for MP258
9. Extract file ServiceTool_V1074
10. Prepare 2 paper in the printer (this is to print at the time the reset process)
11. Run the program ServiceTool_V1074
12. Click the "MAIN", then the printer will proceed, then MP258 will print one page with the words "D = 000.0"
13. Click " EEPROM Clear ".
14. Then click "EEPROM", and the printer will print the results MP258 Re-setter.
"TPAGE(TTL=00000 COPY=00000)"
15. Turn off the printer by pressing the POWER button or unplug the power cable
16. Turn on the printer, and the printer ready to use
I hope this information helps. Thank you for using FixYa!
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
14helpful
6answers
How to fix error P10 on canon mp258
series MP258 printer. According to my experience of Error P10 can be solved by replacing one or more of the following spare parts:
  • Cartridge PG810 or CL811 (can be both).
  • Carriage unit complete with its head cable.
  • Logic Board.
1helpful
How to fix error P10on canon mp258
Canon PIXMA mp258 is a series 3 in 1 printer (print, scan, and copy) in lieu of MP145 and mp198. MP258 printer cartridge uses PG810 series (black) and CL811 (color) so different from the series MP145 and mp198.
It had been several times we found the damage Error P10 (on display) for the series MP258 printer. According to our experience of Error P10 can be solved by replacing one or more of the following spare parts:
  • Logic Board.
Check that easiest of starts before the last of the cartridge until the logic board
2helpful
2answers
Can u help me how to fix canon printing model is mp258 , error number is 6000, what is problem? thanks
Hi cinlytan,
With the error that you're getting with your Canon mp258 , error number 6000 this means that your printer needs to be reset. You will need a software resetter for this specific printer. You may also use the software resetter for its many other errors. Kindly click on this link for the instruction and for you to be able to download the service tool. This should fix the error code that you're getting and other issues with your printer.
Hope it helps.
Thank you for using Fixya.
27helpful
How to fix canon mp258 error code 006
i'm using canon printer mp258, the printer wont print anything after i refill both ink(color & black), the both l.e.d still lid and and the alarm l.e.d still lid and the printer window keep popping telling me the colors now empty..heeeeellllppppp.........
1)try to reset the printer - wont work
2)try using the resetter - wont work(error 006 occur)
k24674
ADMIN Andrew
ADMIN Andrew
