I have a ceiling fan with remote control. My kid dropped the remote control and now the ceiling fan won't turn on the lights or the fan. What can I do?
  • 244 Answers
It may be as simple as removing the batteries and putting them in again. Sometimes they can be jarred loose from their contact points when they are dropped. Try that first and see if it helps.
Posted on Nov 04, 2010
Remote wont work for fan.
http://www.ehow.com/how_6104129_instructions-hampton-bay-fan-remote.html You may need to reprogram the remote
May 15, 2013 | Televison & Video
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
Is there a way to take remote controll off of a fan mine stoped working after kids pulled fan or light pull
My ceiling fan loses remote control every time there is a power outage. The first thing to do is turn off power to the fan at the circuit breaker. Take the battery out of the remote and push all the buttons to eliminate a stuck button as a possible cause. Reinstall the battery. Turn on power to the fan. Check operation. You may have to pull a chain to "reeducate" the remote but you should be back up and running soon.
Dec 31, 2012 | Hunter 52" Ceiling Fan With Light And...
Emerson ceiling fan remote won't work
Check the remote control for its infrared emission. Check its battery contacts for any rust or dust. Check it with fresh batteries.
Nov 05, 2012 | Emerson 44 Curva Sky Ceiling Fan In...
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
10.27.09 - Ceiling Fan Light Kit not Working.
the remote does control the light. i think it's the bottom button, once to turn it on, again to turn it off. there should have been a blue wire connected in to the wires in the ceiling, this is power for the light. if only the white, black, and copper are connected, the light part won't work but the fan will (usually)
Oct 28, 2009 | Hunter 52" Ceiling Fan With Light And...
Remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Apr 22, 2009 | Hampton Bay 24002 Ceiling Fan
Remote vs receiver problem.
This is one of the best solution to do, look for unit who have same model as your unit( to your friends or neighbors) and test your remote control. If it work in another unit with same model then the remote control is defective, but if it works then its the receiver.
But try this solution first, if there is a reset button in your remote try to reset it then try the remote to your unit.
USE POINTED OBJECT TO PUSH THE BUTTON
Jan 03, 2008 | Hampton Bay 52 In. White Redington...
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
