Question about Maytag Washing Machines
I have a maytag washer i bought in 97. It became unbalanced well my husband fixed it and everytime it goes on the spin cycle it gets unbalanced again and makes a very loud noise
  • 244 Answers
If the washer is truly balances (check with a level to be sure) you might just have an unbalanced load. When filling your machine with laundry, think of the tank as a big circle divided into four pie slices. Make sure you fill each of the four slices evenly. This should help,
Posted on Nov 04, 2010
Maytag Centennial Washer - NO SPIN
OK so it sounds to me like your clutch is just slipping sometimes. Because the issue is sporadic it's hard to test for certain what the issue is, but I would recommened ordering and replacing the clutch to fix the issue. Below is a link to a video that shows you how to replace the part if you'd like.
https://youtu.be/tVc6SZ2DD4U
Jun 01, 2017 | Maytag Washing Machines
How do I get my machine to just spin a load? It became unbalanced and I adjusted it and now just want to spin the water out?
Turn power on. Without selecting a cycle, push the spin speed button to select the spin speed you desire. (if you had an unbalanced load, I'd suggest a low spin speed. You can repeat after with the next higher speed if desired) Push start.
This will give about a 12 to 14 minute pump and spin only cycle.
Mar 21, 2011 | LG WM-2277HW Front Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My Washer will work at all. It acts dead
a small run of these actually had an out of balance switch and fuse assembly that cut power to the machine if it went way out of balance ,check and see if yours has one and replace the fuse at first but you may have to replace the entire assembly
Feb 06, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Unbalanced washing machine
there may be shipping bolts that you have to remove.read your instructions 2 see
Jan 02, 2009 | Maytag Performa PAV2200
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Maytag LAT2500AAE- unbalanced
see if it has 4 adjustable feet on each corner on the bottom
get a bubble level from a hardware store and turn the feet to raise or lower OR you could use something else to raise the sides until it is leveled by looking at the bubble level.
hope this helps
thanks for your rating
Jan 09, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
313 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
