Question about Kenmore 24642 Top Load Washer
Maytag Washer- Fills, Spins and empties but does not agitate
I have replaced lid switch, no oil on floor
  • petulant Jun 13, 2008
    Hmm... cut off my subject- sorry
    Does not agitate.
    Genius:
  • 1,073 Answers
Does what???????????????
Posted on Jun 13, 2008
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
Washer fills but won't agitate..
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Maytag Washing Machines
My daughter has a maytag model LSE 1000 stackable washer and dryer yesterday when she was using the washer the buzzer when off to let her know that the washing was done when she open the lid it was still...
The problem could be an issue with the lid switch or also a broken belt. Check to see if the unit will agitate. This washer and a 2 speed motor which spins one way to agitate and the opposite to drain and spin. If the unit sounds like its running then its probably a belt and idler pulley issue. IF the unit is completely dead it could be a bad lid switch, timer, or motor.
Jan 28, 2010 | Maytag Washing Machines
Drum fills with water but won't agitate. spins and rinses fine.
Hi.
If it does not agitate check the variable speed motor, the control unit and the transmission.
Check also the lid switch. A defective lid switch may open the circuit and stop the cycle before agitating.
Nov 13, 2009 | Maytag PAV2300 Top Load Washer
Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Aug 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool top loading washing machine not finishing cycle
SOUNDS LIKE A PUMP HAS GONE BAD. REPLACE IT. IT WOULDN'T COST TOO MUCH.
May 14, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Kenmore 24642 Top Load Washer Logo
75 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
