Question about Air Tools & Compressors
Ween start any time to much black smoke whi - Air Tools & Compressors
  • 297 Answers
I cant under stand your problem with your description. PLEASE clairify.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 04, 2010
Should I start smoking weed?
You should start smoking only if you feel alone and stress otherwise I suggest you don't smoke because weed has some harmful content that can be dangerous for your health and your society.
If you have some health issue like chronic pain, depression, and anxiety then you can Buy Weed Online and take it for reducing it.
Jun 11, 2018 | Garden
Why is my atego 1823 having a hard start in the morning and when it starts it produces a black smoke
Black smoke, real black, is unburnt fuel in the exhaust. If it clears up in a very short time, it may be only due to the extended cranking you have to go through to get it started. If fuel consumption is not awful, it is possible that the hard starting is not a fuel problem. If this is fuel injection, too much gas could be leaking injectors, but as above, if it clears up right away, the smoke was from extended cranking forcing all that gas into the cylinders. You probably should check fuel pressure, always do that for hard starting.
Check your ignition system, use a calibrated spark tester. Need new spark plugs and/or plug wires?
Nov 09, 2015 | Cars & Trucks
Why is my 2001 jeep grand cherokee blowing smoke everytime i am stopped at the red light .
If the smoke is black , the mixture is too rich. If it's white and disappears soon after accelerating, then it's valve stem seals.
Jul 17, 2014 | Jeep Grand Cherokee Cars & Trucks
Why does my car sometimes blow smoke
If it's white smoke, it's oil. If it's black smoke, it's fuel. Make sure you haven't over-filled you oil levels.
If it's worse when you first start it, the oil is leaking down from the valves. You may even have some debris preventing it from flowing back into the block.
May 06, 2014 | 2010 Peugeot RCZ 2.0
My Karizma ZMR 2010 bike giving black smoke
Usually zmr dont have these kinds of problems.your engine bore is gone thats why your engine oil level is reducing.and the black smoke is coming out...usually these problem occur when you are travelling in higher rpm at lower gear...
Dec 25, 2012 | 2006 Hero Honda Glamour
Black smoke coming from exhaust occasionally.
Black smoke is indicative of carbon or incomplete combustion caused by either poor ignition (weak spark) or too much fuel (choke setting). Check out these areas.
Mar 31, 2017 | 2003 Suzuki VL 1500 Intruder LC
Why my nissan pick up doesn`t start when the motor is cold in the morning or when gets cold
is check engine light on this could be a coolant temp sensor issue it could be a fuel psi regulator problem or bad injector or cold start injector if your vehicle is equiped if a diesel bad injectors or injection pump the black smoke is raw fuel
Apr 06, 2012 | Cars & Trucks
My 2002 toyota celica has recently started overheating and smoking, we have topped up the oil checked amnd topped up the water/coolant numerous times and i can drive for maybe a mile before it overheats...
your coolant is not staying in the cooling system, that is why you have to refill it and that is why it is overheating. it is leaving via a crack or bad gasket and going into the combustion or lubrication system and that is why it is not running well. a real mechanic has to put his hands and eyes on it soon.
Dec 20, 2010 | 2002 Toyota Celica
Wite smok from exaust system. When starting some time wite smok and smell of burning oil. Some time do not smoking.Do not pick up from low speed fast. The engine is turbo and inter cooler
Smoke can be from rings worn out, cracked piston, valve guide seals if smokes at start up then stops, fueling issues if fuel is to rich but that smoke is usually black, also if head gasket is blown or head is cracked water burning turns into steam which looks like white smoke. This can also be why won't start just turns over.
Jul 18, 2010 | 1994 Volvo 850
Air Tools & Compressors Logo
22 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Marvin
Marvin
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
