I get a blue screen when I connect my iPhone, what's wrong?
    Genius:
  • 1,148 Answers
Check online for new device drivers for cell and windows ur running
Posted on Nov 04, 2010
How to fix iPhone 6s with blue screen
It is a quite frustrating thing that your iPhone turns into blue color and your phone reboots when you are using one of iPhone apps. The "iPhone Blue Screen of *****" issue leads to our iPhone irresponsible and will affect our normal mobile life a lot. It seems that it's most frequent to U.S. T-Mobile users. iPhone 6, 6 Plus, 5S and others are affected, so there doesn't seem any device related problem. If you are also faced with the "iPhone Blue Screen of *****" issue unfortunately, no worries, here are several solutions for you to fix it.
  1. Update or Delete the Apps
  2. Hard Reset Your iPhone
  3. Update to the Latest iOS Version
  4. Restore iPhone to Factory Settings
  5. Turn off iCloud Sync
Please click the following link to see more details about the solutions.
How to Fix IPhone Blue Screen of *****
Jun 11, 2016 | Cell Phones
Tip
Bluetooth StatusThe Bluetooth icon appears in the iPhone status bar at the top...
Bluetooth StatusThe Bluetooth icon appears in the iPhone status bar at the top of the screen:
  • (blue) or (white): Bluetooth is on and a device is connected to iPhone. (The color depends on the current color of the status bar.)
  • (gray): Bluetooth is on but no device is connected. If you’ve paired a device with iPhone, it may be out of range or turned off.
  • No Bluetooth icon: Bluetooth is turned off.
on Dec 23, 2009 | Apple iPhone 3G
My screen is stuck on plug into the itunes screen
Probably something went wrong, and your iPhone itself sees that too. That's why your iPhone asks to connect it to your PC or Mac with iTunes installed.
-Start iTunes on your PC or Mac
-Connect your iPhone to the PC or Mac
-Probably iTunes will advise to recover your iPhone.
>>If you didn't make regular backups of your data you probably will lose the data that's on your iPhone.<<
-Wait until the recovery procedure is done and see if your iPhone works again.
What if iTunes doesn't recognize your iPhone anymore in iTunes?
Thy a "soft reset' by pressing the ON/OFF button on top of your iPhone and the round menu button underneath your screen simultaneously until your iPhone reboots. Check if your iPhone connects to iTunes and try the recovery.
I hope this will help you solving your problem.
Feb 10, 2014 | Apple iPhone Smartphone
I phone 5
What Type/Brand of router ?????
Apple's iPhone is a multimedia connectivity tool.
As such, the iPhone employs a sophisticated system to keep you connected to the web via WiFi signals so that you can stay up to date with email, mapping and media.
To use the iPhone's WiFi feature just follow these steps.
Tap a network.
If you have not yet used your iPhone's WiFi or if you're in a new WiFi area, the iPhone will show you a list of available networks.
Tap the network that you want to connect to in order to connect.
If there is a password required a little lock icon appears.
Enter the password to connect to locked networks and continue to surf the web.
Monitor your signal.
As you use your iPhone, especially if you're moving around, you should take a look at the signal strength of the connection.
The strength is indicated by a small, black broadcast symbol that stacks arches, or rounded bars, on top of one another.
The more bars there are the better the signal.
Make connecting to WiFi automatic or manual.
The iPhone is equipped to automatically search for available networks and connect you to one.
If you do not want the phone to search for networks, select the "WiFi" option on the phone's menu.
Then select either the on or off option of the "Ask To Join Networks."
Turning this option off requires that you find networks manually.
Forget a network.
Once you connect to a WiFi network once the iPhone automatically remembers the network and connects you to it at a later opportunity.
To forget a network so you don't get automatically connected choose the "WiFi" option on the menu.
Then tap the right arrow button next to one of the networks that the iPhone already remembers. Then tap "Forget This Network" to erase the phone's memory of the network.
Troubleshoot Wi-Fi Connection Problems on an iPhone
If you experience Wi-Fi connectivity issues on your iPhone, you may need to reset the Wi-Fi connection.
Your connectivity issues could be caused by the wrong password if you are having trouble logging into the Wi-Fi network or from a problem in your iPhone's settings.
By resetting the Wi-Fi connection, you are clearing out the previous settings created when you first connected to the network.
Tap the Settings icon on the iPhone's home screen, and tap the Wi-Fi tab.
Swipe the switch on the Wi-Fi tab to ensure Wi-Fi is enabled on your iPhone.
Tap the blue arrow button on the network tab you are connected to in the network list, and tap "Forget this Network."
Tap the "Forget Network" button that appears on the pop-up menu to confirm the action.
Tap the Wi-Fi Networks tab in the upper-left corner to return to the previous screen, and tap the network's tab in the network list to re-join it.
Press the Home button on the iPhone, and tap the Safari icon on the home screen to test the Wi-Fi connection.
Tap the blue arrow icon on the network's tab if the connectivity problem persists, and tap the "Renew Lease" button at the bottom of the network's window.
Tap the "Renew Lease" button on the pop-up box to confirm the action.
Tap the Home button on the iPhone, and tap the Safari icon on the home screen to test the network connection.
Nov 11, 2013 | Computers & Internet
Iphone won't turn on, just blue screen
Did it get wet. that sounds like something that would happen if it got wet. if you don't know that it got wet you could shine a light into the headphone jack and look for a white sticker. if wet the white sticker will have turned reddish
Jan 24, 2013 | Apple iPhone 4S
Iphone screen is all blue nothing works
Hi, This is probably too late but I really hope this can help you or others. Firstly, we need to know what cause the Red Screen Issue: A. Your iPhone Device Has A Hardware Problem B. Your iPhone device has been jailbroken C. Your iPhone device has a failed software update Secondly, Here are some common solutions to fix Red Screen of ***** Issue: A. Perform A Soft Restart on Your iPhone Device B. Perform A Force Restart on Your iPhone Device C. Restore Your iPhone's Default Factory Settings D. Bring Your iPhone into DFU Mode E. Update Your iPhone to The Latest Software Thirdly, If the common solutions could not solve your problem. You can try an data recovery software - FoneDog toolkit. Step 1: Download, install and launch FoneDog Toolkit. Step 2: Proceed to System Recovery. Step 3: Review Reminders before The Recovery Process. Step 4: Download The Firmware. Step 5: Downloading and Repairing Step 6: Repair is Complete More Information you can see: Ways to Fix Red Screen Issue in iPhone Device The red screen issue in iPhone devices is truly a bothering issue to have since it can stop you from being productive in using the phone or making it fully functional. Through the common solutions we have shared above for fixing such issue, as well as the help of FoneDog toolkit, we hope that the red screen issue in your iPhone has now been fixed. Hope it can help you! 5 Ways to Fix Blue Screen Of ***** in iPhone Device
Jun 10, 2012 | Apple Cell Phones
Connect to iPhone 4
Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. The location of the button may vary based on which headset you have, but its appearance will be the same; it is the button that has an image of a telephone on it.
Click on the "Settings" icon from the main screen of your iPhone 4 .
Click on "General" in your iPhone's "Settings" menu.
Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
Click on "OK" on your iPhone 4 to complete the connection to your Jabra headset.
Tips & Warnings
The LED light on your headset must be solid blue to pair to your iPhone. A flashing light indicates your headset is not yet in pairing mode and your iPhone will not be able to connect to the headset.
Having your iPhone 4 Bluetooth turned on will drain your phone battery faster than normal.
Apr 13, 2011 | Jabra Bluetooth Headset - BT2070
When i plug my iphone in to my pc (windows xp) the pc shuts down and displays a blue screen, without photos on the iphone, i can connect, is there a fix for this.
Don't know about iphones but I have had a lot of trouble with iPod connectivity to PCs. Solution was to connect with firewire and not USB.
HTH
Aug 29, 2009 | Toshiba Satellite M105-S3004 Notebook
Blue screen of death
Update the Operating system.
Update the Iphone too
Should cure the problem.
Richard.
Apr 20, 2009 | Acer Aspire 3680 Laptop
Computers & Internet Logo
16 people viewed this question
Alun Cox
David Payne
David Payne
