Question about E-Machines eMachines Desktop PC
Emachine t7242 yesterday i wasnt able to turn my computer on it is stuck. It makes just a ticking noise i cant turn it off without unplugging it. it wont go past this. thought it was the power supply. bought new one it didnt help. replaced the cooling fan still doing same thing help what is the problem here?
  • 4,472 Answers
The ticking sounds like it could be your hard drive failed. The computer is not making any beeps or anything? just the ticking? If the pc is under warranty I would definetly handle it that way. If this is not the answer you are looking for please disregard.
Good luck,
Lee
Posted on Jun 13, 2008
Hi I turn the heat on in my 06 dodge magnum I hear a ticking noise then goes away now no ticking noise and no heat
Could be your blend door getting stuck thats making that ticking noise. Check your heater hoses to make sure they are getting hot. Check with caution theu may be very hot.
Jan 02, 2016 | Dodge Cars & Trucks
Haier dryer makes ticking noise
The ticking noise could be either a piece of the belt hitting as it spins around, it could be something stuck in the drum that is hitting it as it turns too, or it could be the electric motor making the noise. Either way it sounds like you may need to tear it apart to see what's going on.
Jul 18, 2014 | Haier HLP140E Electric Portable Dryer
My emachine keeps making a "rev-ing up noise when
That is the cpu cooling fan speeding up and slowing down. There is only one thing to do, switch the unit off and save some power.
Dec 29, 2010 | E-Machines eMachines Desktop PC
The dryer makes a new noise now when the drum is turning. It is a steady "tick -- tick -- tick -- tick --etc" which is laid over the normal sounds of the motor, the turning drum, and the...
You have done a good job of isolating the noise. Sounds like you will have to replace your drive motor. Very likely a mechanical problem in your motor, that is not going to fix itself. If you continue to run your dryer with the noise coming from your motor, you run the risk of the motor burning out electrically and causing a fire or a shock hazard. It is unlikely that this will happen, but it is possible and thereby not worth the risk of getting shocked or having a fire. The Whirlpool Duet Dryer is the best dryer built, so it is worth replacing the motor. Good luck, Appliance Specialists
Dec 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a 13 month old Acer Aspire ax1700 Desktop. Had turned it on yesterday and Fan was making lout noise. Today I turned it on to check it. Was on for about 10 minutes and it just turned off. There are 2...
It seems that the power supply unit has gone. If you power it on and nothing happens then obviously the psu has gone. The heat that you felt was the psu overheating because of no fan and hence no ventilation. The noise was of the faulty psu fan that got stuck or did not work and the psu got overheated and got burnt eventually. Please replace it with a new one as a repaired psu may work but you cant rely on it.
Mar 22, 2010 | Acer Aspire AX1700-U3793A PC Desktop
My blazer is making a ticking noise. I have changed the belt,pulley, and recently the water pump. It now only makes the noise when I give it gas.What could be the problem?
can be anything if coming from upper engine possible problem in head[s] valve tick if truck overheated and oil wasnt changed also may have sludge in engine causing limited oiling of valves,lifters rockers or a valve needs adjusting rocker loose can also be from the parts u replaced need to listen to where noise is coming from
Feb 08, 2010 | 2000 Chevrolet Blazer
Contrast/menu/screen resolution box wont stop flashing on screen.
try to clean around it's exit button sounds stuck
or unplug monitor for about 20 minutes
if the problem persists i would reinstall driver
Jan 09, 2009 | E-Machines eMachines Desktop PC
Won't turn on, ticking noise that continues when unplugged
Bad flyback transformer.....Emerson parts source ..Fox international or the partstore.com ...............T.
Jan 15, 2008 | Emerson EWF2703 27" TV
Ipod wont show up on itunes
try these websites. it can be a frustrating problem.
http://www.apple.com/support/ipod/five_rs/classic/
http://docs.info.apple.com/article.html?artnum=93716
make sure you follow all of the steps
good luck
Dec 14, 2007 | Apple iPod nano
E-Machines eMachines Desktop PC Logo
69 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
